  for you then is the same, if someone wrote this is noisy resistor, then you don't care for that material, because it is the same from 10 ohms to 1000000 ohms all are noisy on the same level
Sounds like one more reason to consider alternatives within the power supply If mox are noisier within any given application .
I can't say if this is the same article, but do I have this one page about resistor noise (a section of a larger text about resistors in general) bookmarked.WhopperPlate wrote: ↑Mon Feb 20, 2023 3:09 pmI remember someone here once posted an article discussing how resistor noise significantly contributes to the tonal nuances of each resistor . I can’t cite it or find it but I remember reading about it allmartin manning wrote: ↑Mon Feb 20, 2023 3:04 pm MOX are noisy. I still wonder if this resistor mojo isn't just about noise.
Right up until you notice that in power supplies, the resistors are bypassed to ground with BFCs (Big Freaking Caps). The noise is reduced by the filtering effect of the caps and even more so by later-in-the-chain resistors and bypass caps, which further reduce the noise, as well as any common mode rejection of circuit stages. Even the full thermal-plus-excess noise of a resistor in the power supply is tiny compared to the power supply voltage itself.WhopperPlate wrote: ↑Mon Feb 20, 2023 7:47 pmSounds like one more reason to consider alternatives within the power supply If mox are noisier within any given application .
Not so much worry , just one more consideration in the sum of the parts. Thanks for the technical demo .R.G. wrote: ↑Mon Feb 20, 2023 10:05 pmRight up until you notice that in power supplies, the resistors are bypassed to ground with BFCs (Big Freaking Caps). The noise is reduced by the filtering effect of the caps and even more so by later-in-the-chain resistors and bypass caps, which further reduce the noise, as well as any common mode rejection of circuit stages. Even the full thermal-plus-excess noise of a resistor in the power supply is tiny compared to the power supply voltage itself.WhopperPlate wrote: ↑Mon Feb 20, 2023 7:47 pmSounds like one more reason to consider alternatives within the power supply If mox are noisier within any given application .
Even the use of carbon comps in power supplies doesn't make the power supplies noticeably noiser, and they were used there in lots of vintage circuits when their power rating was enough. MOX, being lower noise, even if not perfect, also would make little difference to a power supply output.
Questions like this are where being able to express things in numbers is a huge advantage. Ever lower noise resistors only matter when their noise voltage/current outputs are large enough to matter compared to the circuit voltages. I did a quick calculate of the thermal noise of a 10K resistor (only the resistance and temperature matter for thermal noise) at 25C. It came out to 1.283 microvolts. Compared to a 400V B+, that's -169.9db. But there is also excess noise, where CC has problems. Excess noise is current noise, which varies as 1/F. At 82 Hz (excess is worse at lower frequencies) a 10K CC resistor has an excess noise of (as nearly as I can squint the graph) 23db more than a MOX. MOX is about 6db higher than wirewound, which is substantially the same as its thermal noise. (https://pub.dega-akustik.de/ICA2019/dat ... 001261.pdf)
So we could estimate that a 10K MOX would have -164db thermal plus excess noise at 82Hz, tapering to -170db by ~400hz.
Why would we worry about MOX noise in power supplies?
I'm not familiar with calculating a signal to noise ratio using a DC power supply voltage as the "signal" that the noise is relative to. Wouldn't it be more appropriate to do a S/N calculation using the ripple voltage that rides on top of the 400V B+?R.G. wrote: ↑Mon Feb 20, 2023 10:05 pm Questions like this are where being able to express things in numbers is a huge advantage. Ever lower noise resistors only matter when their noise voltage/current outputs are large enough to matter compared to the circuit voltages. I did a quick calculate of the thermal noise of a 10K resistor (only the resistance and temperature matter for thermal noise) at 25C. It came out to 1.283 microvolts. Compared to a 400V B+, that's -169.9db.
  Iskras might do.
 Iskras might do.
I call that “riding the elephant”… some people look at you when you hit the standby switch like you shot their dog …Reeltarded wrote: ↑Tue Feb 21, 2023 10:56 am Tube amps are not ideal circuits. What perfection do we strive for? For most of my life I have been willing to play a waterfall of hiss louder than many bands and control the breakdown of reality with my pinky on a volume knob. Do you have any idea what a Super Hard On thru an AC30 does? Yikes.
*imagine your band owns a 707 and it's parked in your house and kept running*
Ah cmon , quit teasing me
I'm not familiar with calculating signal to noise on a DC power supply output either. I had always just assumed that resistor noise in a power supply could be ignored as too small to matter on the power supply output. I did the math to sound out my internal assumptions. In this one instance, my assumptions were correct: even if you ignore noise reduction by capacitor filtering, the noise of a MOX resistor is incredibly trivial in a power supply. Even an extra-noisy CC's noise is too small to worry about in a power supply, by the numbers.
Now you're on it! The question is what are the circuit-appropriate numbers? Good on you.Or, even better, what would the S/N ratio be with a 100k resistor on the plate of a triode? That seems like some math that would be pretty appropriate considering the source you linked is primarily focused on the passive intermodulation (PIM) that distorts an actual signal by intermodulating it with noise.
For whatever it's worth, CCs are not just CCs. I suspect that modern-manufacture CCs have had their binders changed since the Golden Age. Most of the techie stuff I've read about what makes CC especially good or bad attributes the good or bad to the binder, not the carbon granules so much. A discussion of CC versus other types probably needs to include some discussion of the binders.WhopperPlate wrote: ↑Tue Feb 21, 2023 3:39 pm Fwiw Koa Speer and yageo still produce higher wattage cf in many values
Great good for thought! I have heard this argument with modern Cc . I honestly don’t care for Cc within the signal path for most things , so I never nerded out down that rabbit hole . I just use whatever nos I can find for the b+. Obviously not very sustainable , but it is what it isR.G. wrote: ↑Tue Feb 21, 2023 4:28 pmFor whatever it's worth, CCs are not just CCs. I suspect that modern-manufacture CCs have had their binders changed since the Golden Age. Most of the techie stuff I've read about what makes CC especially good or bad attributes the good or bad to the binder, not the carbon granules so much. A discussion of CC versus other types probably needs to include some discussion of the binders.WhopperPlate wrote: ↑Tue Feb 21, 2023 3:39 pm Fwiw Koa Speer and yageo still produce higher wattage cf in many values
AAAACK! THE BINDERS!!??!! Who knows what the Golden Age binders were, what the modern binders are and are not, and what that change does compared to the decades-old binders in decades-old CCs. Were Golden-Age CCs as good when new as we think they are now? We know the Golden Age resistors have changed by aging over the years, because drifted resistors are a very, very common issue with repair techs.
This leads to the question - how valuable is the advice to use or not use CCs in the face of all this quicksand? Is there some way to actually tell whether new CCs are as tone magic as older CCs. Or better? Is older better, in which case we might start aging new CCs before use, or is modern CC better, and how?
Amazing the extent of the potential variability imparted by simply noise … fascinatingmartin manning wrote: ↑Tue Feb 21, 2023 4:24 pm
In audio circles it's definitely a fringe element that talks about the sound qualities of different resistors other than their noise level, and there are market forces around some basic human desires at play in that area. I'm definitely in the "it's just noise" camp, but I'm open to the idea that the presence or absence of noise in the audio may alter the perception of other frequencies and harmonics.
