I've made a start :) 50w #102
- norburybrook
Re: I've made a start :) 50w #102
well it makes a noise.............
the relays aren't working at all the tone controls are not doing anything except for the treble which seems to be acting like a volume?????????
I had a feeling the relays were going to be my Waterloo.
whats the first thing for me to check with the relays tomorrow? I was balancing Martins layout with the boards I had as they're slightly different.
see pic
I'm off to bed now, tomorrow is another day.
Marcus
see pic
Marcus
I had another look and I believe I had the transformation done correctly.  Here's another mark-up with your photo reversed to show the boards as viewed from the top side and updated for "no R/J." Check your connections against this and see if you see anything amiss.
						- norburybrook
THanks Martin, looking at that I can see I've wired mine completely differently as I used the ceriatone layout as well as your original one.
My relays are 5v and I've got 4.9v coming from the regulator however I've got 18v coming into the regulator from the transformer/board, that seems like the a lot to me as the regulator is doing an awful lot of work to get from 18 to 5 v or is that OK?
Just checking the transformer info again and it should be putting out 6v , don't know why I'm getting 18v coming off the relay board.
Marcus
Marcus
I'm using Tony's layout. Your OD board looks like the Ceriatone, but I have shown it wired like Tony shows with OD on when the relay is energized.
The relay supply is using a voltage doubler. Is the relay transformer center tapped? If so you can just use half of the winding into the rectifier and cut the DC going into the regulator in half.
- norburybrook
martin manning wrote:I'm using Tony's layout. Your OD board looks like the Ceriatone, but I have shown it wired like Tony shows with OD on when the relay is energized.
No there's no center tap on the relay transformer.
http://uk.mouser.com/Search/ProductDeta ... 553-F-313X
is the regulator going to be ok taking 18v down to 5v? It's obviously going to be putting out a lot of heat but that will go through the chassis as a heat sink, just worried it might melt the solder if it get to hot.
Marcus
It should be ok. The power dissipation depends on the current draw, and you are not asking for much powering a couple of low-current relays and LED's.norburybrook wrote:Is the regulator going to be ok taking 18v down to 5v? It's obviously going to be putting out a lot of heat but that will go through the chassis as a heat sink, just worried it might melt the solder if it get to hot.
Not a bad idea to get in the habit of reading data sheets. If you look at the data sheet for just about any LMxx linear regulator, the max input voltage is around 36-37 volts.norburybrook wrote:
Marcus
TM
- norburybrook
ToneMerc wrote:Not a bad idea to get in the habit of reading data sheets. If you look at the data sheet for just about any LMxx linear regulator, the max input voltage is around 36-37 volts.norburybrook wrote:
Marcus
TM
LOL point taken, I feel duly chastised
 Got to do some proper work today in the studio ( mixing a new album for http://www.lucindadrayton.com/ ) so I'll get onto this in the evening.
Not looking forward to getting those relay boards out and rewired.
Marcus
Marcus, no need to feel chastised and wasn't intended as such, just a friendly tip.norburybrook wrote:
Marcus
TM
- norburybrook
ToneMerc wrote:Marcus, no need to feel chastised and wasn't intended as such, just a friendly tip.norburybrook wrote:
Marcus
TM
 no problem.  I am eternally grateful to everyone here for their help, especially my mentor Martin, you'll make an amp builder of me yet
now back to my mixing.
Marcus
- norburybrook
Martin,
what exactly do you mean by:
overdrive IN/OUT and CI out on the relays?
Marcus
Marcus
OD out is the output from the OD section, which would be the Ratio pot wiper.
OD in is the input to the OD section, which is the resistor/trimmer pot going to the V2a grid.
Cl out is the output from the clean section, which is the cap coming from V1b's plate.
					Last edited by martin manning on Mon Jan 26, 2015 8:39 pm, edited 1 time in total.
				Charlie Wilson
Marcus,
CL out or clean out goes from the .05 V1b coupler to your relay. Overdrive in goes from your relay to the 220k OD entrance resistor. Overdrive out goes from your OD volume(ratio) to the relay and MV3 goes from the relay to your global master volume. OOps Martin got there first. Marcus don't get frustrated. This is the part of building were you carefully think through the issue, solve it, and learn something.
CW
CW
- norburybrook
indeed , I was just saying to friend today, when my JTM45 didn't work first time , the week I spent trouble shooting was such a great learning experience I'm glad it worked out that way.Charlie Wilson wrote:Marcus,
CW
At the time though it's quite frustrating
thanks for the replies guys, back to the iron..............
M
- norburybrook
Ok wired up exactly as the picture and still not working.
should I hear the relays switch if they're working?
also the amp is very quiet and thin, there's a faint high pitch background noise and if I switch the impedance selector from the 16ohm its now at, to the 8 and then 4 it get louder as I hit the 4 ohm. the NFB is connected to the 4 ohm so I presume it's something to do with that.
is this my output primaries? I remember the squeal being quite loud with my last build when I got them the wrong way round.
Marcus
Marcus
