Dumble - help needed urgently!
Re: Dumble - help needed urgently!
No problem having most things already done, I could see from your pictures that you had completed a lot of the wiring.  Think of the steps I'm describing as identifying the group of connections and parts to double-check before applying power and testing that section of the circuit.
Yes, the routing of the wires and the location of the grounds is important. There is more than one way to do it, but it's a system and you want to keep it intact.
When you get power on next, measure the induced VAC on the OT secondary as I suggested above. Your OT is rotated 90 degrees from the usual Dumble build, so lets see if that is going to create any objectionable hum. Assessing that at this point will keep you from having to chase down the source later.
BTW, where are you located 'internationally?'
				Mousey Dung
Love your systematic approach! After I posted that shot of the underside, I actually changed my mind about the 90-degree orientation and drilled some new holes to reposition it as it usually appears in other builds, realizing it was critical to the hum factor. Then I discovered that I'd positioned it badly and the main board couldn't be mounted, and I had to redrill four more holes to get it right. Thus my question #8 about the holey underside of the chassis near the OT.martin manning wrote:When you get power on next, measure the induced VAC on the OT secondary as I suggested above. Your OT is rotated 90 degrees from the usual Dumble build, so lets see if that is going to create any objectionable hum. Assessing that at this point will keep you from having to chase down the source later.
I'm based in Northern Europe, get around quite a bit on tour with bands primarily comprising Americans.martin manning wrote:BTW, where are you located 'internationally?'
OK cool. BTW, I only suggested not soldering the 4-ohm tap because there is another wire (the negative FB) going on that lug.  You can leave what you have.  As I said, with the tubes out the current paths in the HV circuits are opened.
				Mousey Dung
Okay, here's the test result sfter connecting PS board and powering on (standby switch off). The limiter bulb lit up, then dimmed to a low glow.
The voltages at the rectifier board were:
Relay: 6 V
B+ plate supply: 455 V
Bias supply: -59 V
The voltages at the seven nodes of the PS board were:
- Power amp V5-V8 plates: 454 V
- all other points: 0 V
On flipping on the standby switch, the limiter bulb lit up, then dimmed again. With the back-panel bias trimpots at their most negative point, the voltages at the various points were as follows:
- Relay: 6.8 V
- B+ plate supply: 446 V
- Bias supply: -59 V
- Power amp V5-V8 plates: 446 V
- Power amp V5-V8 screens: 446 V
- Clean V1 plates: 399 V
- OD V2 plates: 403 V
- Phase inverter V4 plates: 445 V
- Reverb rectifier V3b plate: 443 V
- Reverb driver Trans/V3a plate: 442 V
The power-tube plate and screen voltages:
V8 plate (pin 3): 445 V
V8 plate (pin 4): 8 V
V7 plate (pin 3): 445 V
V7 plate (pin 4): 8 V
V6 plate (pin 3): 447 V
V6 plate (pin 4): 9 V
V5 plate (pin 3): 445 V
V5 plate (pin 4): 13 V
Most negative point at wipers of both bias trimpots on back panel: -59 V
The voltage between the OT common (black wire) and the 16 Ohm (orange wire) was so low it showed up as 0.00 VAC on my digital multimeter (on which the lowest selector setting is 20 VAC).
Is that okay so far?
Relay: 6 V
Bias supply: -59 V
- Relay: 6.8 V
				Mousey Dung
Shall I proceed to completing the wiring of the preamp board next?
It all looks good except for the 8-13V on pins 4 of the power tubes (screen pins).  That voltage should be essentially the same as on the power supply board at the screen node eyelet.  You need to figure that out.  Not much going on there, just a few bits of wire and the four 1k 5W screen grid resistors. Is the wire from the right side pair of screen resistors to the power supply board missing?
On the OT 0 VAC from 16-ohm tap to common, are the speaker jacks wired in at this point? If so they are shorting the output, and you will have to put a 1/4" plug into the main speaker jack to open its shorting contact, or just plug a speaker in there and listen.
Do you have the lavender and burgundy bias supply wires connected from the bias trim pots to the 220k resistors on the board, and the brown and the blue power tube grid wires connected from the other end of the 220k resistors to power tube pins 6? If so you can check pins 5 and 6 for the negative bias voltage.
				Mousey Dung
Of course! I forgot to connect the last red wire going to the terminal lug above V6 and V7.martin manning wrote:It all looks good except for the 8-13V on pins 4 of the power tubes (screen pins). That voltage should be essentially the same as on the power supply board at the screen node eyelet. You need to figure that out. Not much going on there, just a few bits of wire and the four 1k 5W screen grid resistors. Is the wire from the right side pair of screen resistors to the power supply board missing?
Now all the voltages at V5 to V8 are the same:
pin 3: 451 V
pin 4: 450 V
Yes it is soldered. I will try it with a jack plugged in there. Don't have a 16-Ohm speaker to test it with.martin manning wrote:On the OT 0 VAC from 16-ohm tap to common, are the speaker jacks wired in at this point? If so they are shorting the output, and you will have to put a 1/4" plug into the main speaker jack to open its shorting contact, or just plug a speaker in there and listen.
To the main preamp board? Yes.martin manning wrote:Do you have the lavender and burgundy bias supply wires connected from the bias trim pots to the 220k resistors on the board
Yesmartin manning wrote:, and the brown and the blue power tube grid wires connected from the other end of the 220k resistors to power tube pins 6?
Will do that and report results shortly.martin manning wrote:If so you can check pins 5 and 6 for the negative bias voltage.
				Mousey Dung
Done. They are now showing as:martin manning wrote:check pins 5 and 6 for the negative bias voltage.
Pins 5 & 6 on V5 & V6: -57 V
Pins 5 & 6 on V7 & V8: -58 V
The voltage between the OT's black and orange leads still shows up as 0.0 VAC on my DMM.
Great! You don't need a 16 ohm speaker, I picked that for measuring with the meter because it would be the most sensitive. Zero VAC on the OT is good- no hum!
On to the preamp board. Connect up the power supply and check voltages on the preamp tube plates (pins 1 and 6) to be sure it is getting through.
When all the other wiring is done, do the heater wiring from V8 to V1. You will want to twist the wires and elevate them above the centerline of the tube sockets. Use two different colors of wire and connect the same color to the same power tube pins and preamp tube pins. For example all pins 7 on the power tubes and all pins 9 on the preamp tubes are connected with the same color, meaning they are all on the same side of the filament winding. Like this: https://tubeamparchive.com/viewtopic.ph ... 903#318903
					Last edited by martin manning on Sun Oct 05, 2014 9:11 pm, edited 1 time in total.
				Mousey Dung
I plugged in an 8-Ohm speaker. Dead silent!martin manning wrote:Great! You don't need a 16 ohm speaker, I picked that for measuring with the meter because it would be the most sensitive. Zero VAC on the OT is good- no hum!
Doing that now...martin manning wrote:On to the preamp board. Connect up the power supply and check voltages on the preamp tube plates (pins 1 andto be sure it is getting through.
Not sure how I'm supposed to do this. Are you referring to connecting the 6.3V green wires from the PT to pins 2 & 7 of V8 and then stringing it along to the other tube sockets?martin manning wrote:When all the other wiring is done, do the heater wiring from V8 to V1.
UPDATE: Ah, I see you updated your post. I understand. Thanks!
Sorry, pins 1 and 6 are the plates on the preamp tubes.
				Mousey Dung
After connecting the preamp board, these are the voltages at the preamp tube plates:martin manning wrote:On to the preamp board. Connect up the power supply and check voltages on the preamp tube plates (pins 1 and 6) to be sure it is getting through.
V1 pin 1: 392 V
V1 pin 6: 393 V
V2 pin 1: 397 V
V2 pin 6: 394 V
V3 pin 1: 437 V
V3 pin 6: 443 V
V4 pin 1: 438 V
V4 pin 6: 440 V
Great, looks like you are all set there.
If you have the relay supply connected to the main board (red wire from the rectifier board) and the three wires from the relay coils to the back panel switches, you should be able to operate those switches and hear or feel the relays pull in.
Got the filaments wired yet? Anything else left to wire up?
				Mousey Dung
I'm trying to find the right wire for stringing the filaments. together. The kit came up quite short in this regard.martin manning wrote:Got the filaments wired yet?
QUESTION #9:
Will wires with these specs suffice, since we're dealing with 6.3 V?
- Cable type: wire
- Diameter: 0.5 mm.
- Cross section: 0.2 sq. mm.
- Insulation: 1.4 mm., PVC
- Conductor: tin-plated copper
- Rated voltage: 60 VAC/DC,
- Test voltage: 900 V
- Temperature range: -15 to +65 degrees centigrade
As far as I can tell, that's pretty much it for the amp section after the filament wires are all connected.martin manning wrote:Anything else left to wire up?
The relay power is connected and chained to the bottom left pin of all three relay sockets. I will mount the relays and see if I can detect any relay triggers.martin manning wrote:If you have the relay supply connected to the main board (red wire from the rectifier board) and the three wires from the relay coils to the back panel switches, you should be able to operate those switches and hear or feel the relays pull in.
I might be wrong, but when I look at the diagram, to my untrained eyes, the PAB switch appears to go to the left relay, which then connects to the mid control.
QUESTION #10:
Are the back-panel PAB, Mid and OD switches all correctly routed in the diagram?
				Mousey Dung
QUESTION #11:
What should I do next once the filament 6.3 V wires are twisted and strung along to all the tube sockets?
