Manzamp!
Re: Manzamp!
Anyone reading this make faceplates or can suggest someone to make it? I can supply a PDF or vector graphic file exactly the way I want it.
						Re: Manzamp!
Another possibility for V2, V3 is a 12BZ7 which has the same gain as a 12AX7 but has a higher plate dissapation and voltage rating...
TT
						TT
Re: Manzamp!
You can call Jeanne an BNP Lasers have a look here http://www.bnplasers.comic-racer wrote:Anyone reading this make faceplates or can suggest someone to make it? I can supply a PDF or vector graphic file exactly the way I want it.
They can use various different formats.
Geoff
Re: Manzamp!
Thank you, I'll check it out.lovetone wrote:You can call Jeanne an BNP Lasers have a look here http://www.bnplasers.comic-racer wrote:Anyone reading this make faceplates or can suggest someone to make it? I can supply a PDF or vector graphic file exactly the way I want it.
Geoff
						Re: Manzamp!
Today I worked on the grounding map. In the pictures I can see only the buss bar as a ground. All the other sites are hidden. For example there likely would be star grounds near the EL34s and I'm figuring the are on the plane of the chassis where the transformers are mounted, rather then on the plane where the tubes are mounted. Due to the angle of the photograph, they can't be seen. For the presence ground, I'll do like #124 and ground it to the speaker jack. I'm going to ground the buss bar to the input jack.
I also added one ohm resistors to cathodes on the EL34s. Most accurate schematics and pictures show these resistors on Dumble's other amps.
				Guitarman18
Re: Manzamp!
ic-racer wrote:
Don't forget that #124 presence was grounded at the signal access jacks and not the speakers AFAIR.
Are you under soldering you PCB traces as HAD did to help with corrosion/current handling?
Paul.
						Hi ic-racer, great to see you back on top form, I'm looking forward to following this thread to it's conclusion. Please don't stop half way through and have a two year gap in the middleFor the presence ground, I'll do like #124 and ground it to the speaker jack
Paul.
									'Beauty is in the ear of the beholder'
						Re: Manzamp!
I love this! CSI- Amp Garage. Where's my popcorn...
						Re: Manzamp!
Yes I forgot. I think I'm still OK putting it on the output jack. The OT will be grounded there also.Guitarman18 wrote:ic-racer wrote:Don't forget that #124 presence was grounded at the signal access jacks and not the speakers AFAIR.For the presence ground, I'll do like #124 and ground it to the speaker jack
Paul.
I will be doing the solder on the back.
						Re: Manzamp!
Got a bunch of stuff in the mail today. Just about everything to finish it except the 9 pin sockets and tubes.
[IMG 768]http://img.photobucket.com/albums/v670/ ... ile-17.jpg[/img]
[IMG 728]http://img.photobucket.com/albums/v670/ ... ile-16.jpg[/img]
						Re: Manzamp!
This is such a cool project.  Nice job working this out.
						Re: Manzamp!
Agreed, this is great entertainment and largely FREE!
Ice, you have to post You Tube clips of the amp when it is finished.
Yours Sincerely
Mark Abbott
						Mark Abbott
Re: Manzamp!
I got all the eyelets on the board.
[IMG 768]http://img.photobucket.com/albums/v670/ ... ile-18.jpg[/img]
						Re: Manzamp!
Another test fit of the components and chassis:
[IMG 768]http://img.photobucket.com/albums/v670/ ... ile-19.jpg[/img]
						Re: Manzamp!
Thanks. I'll check it out.ampdork wrote:Mojotone does faceplates now too.
