	Moderators:  pompeiisneaks , Colossal
								bnwitt
		Posts:  379 Joined:  Sat Feb 25, 2006 7:51 pm
						Post
								by bnwitt  Fri Dec 05, 2008 9:36 pm
			I've got it now, but I had to wrap my head in aluminum foil for an hour before it came to me.
Great things happen in a vacuum
								gahult
		Posts:  393 Joined:  Sun Jun 01, 2008 6:20 pmLocation:  Rutledge, GA
						Post
								by gahult  Fri Dec 05, 2008 10:56 pm
			OK, I just gatta.
I've heard they sound better with the stripy end north.....
First ya need a compass, then you need to orientate the thing. Does north stay north when you flip the chassis over or does it all go south
What about the guts in Australia
 Does the arrow go on the other end of the compass needle
Gary
In the 60's people took acid to make the world weird. Now the world is weird , and they take Prozac to make it normal.
								paulster
		Posts:  1299 Joined:  Tue Oct 10, 2006 5:08 pmLocation:  Los Angeles & London
						Post
								by paulster  Fri Dec 05, 2008 11:09 pm
			Unless the volume pot is on full, the output from the pot is going to be lower than the input, so if you're going to introduce any noise, the signal/noise ratio will be higher if the noise is introduced at the input rather than the output.
The two caps left hanging when the switch is in the middle position will be a more effective antenna than the short piece of wire to the middle lug of the switch, so this method of wiring definitely makes sense.
I'm not going to swap mine round to quantify the difference though!
Paul
								bnwitt
						Post
								by bnwitt  Fri Dec 05, 2008 11:40 pm
			paulster wrote: I'm not going to swap mine round to quantify the difference though!
Paul
Well if you don't, forget about using that amp in any band named
"Gnats Ass"
You'll just be to darned loosy goosy.
								drhulsey
		Posts:  986 Joined:  Sun Mar 18, 2007 3:19 am
						Post
								by drhulsey  Sat Dec 06, 2008 12:46 am
			gahult wrote:  ... First ya need a compass...
You're thinkin' right, Gary, but it's how you STORE the resistors that counts
  You need to align your little plastic storage drawer or envelope north to south, with the "little stripy end" north
 After one year, it's permanently polarized unless you play at the North Pole
Tim
								Ron Worley
		Posts:  908 Joined:  Mon Dec 24, 2007 8:21 pmLocation:  Keller, TX
						Post
								by Ron Worley  Sat Dec 06, 2008 8:20 pm
			OK, Tim and I have made the changes that have been noted and I cleaned up several things on the layout.
I will make another thread to announce the changes for the Express and Liverpool that we just completed.
Now, where is that tin foil???
Ron
								Wayne
		Posts:  330 Joined:  Thu May 29, 2008 2:10 am
						Post
								by Wayne  Sat Dec 06, 2008 10:15 pm
			So should we assume that from now on all layout diagrams will include a compass rose?
W
								Ron Worley
						Post
								by Ron Worley  Sun Dec 07, 2008 12:52 am
			Yes, with a GPS option for those who are really in the dark.....
Ron
								drhulsey
						Post
								by drhulsey  Mon Dec 08, 2008 2:16 pm
			Ron Worley wrote:  ... those who are really in the dark...
I can't see, I can't see
Tim
