124 Layout Revised
ic-racer
Re: 124 Layout Revised
Post by ic-racer »
talbany wrote: ic-racer I thought you posted a nice rundown of the specs of 124 voltages etc..somewhere.
Here is the most accurate info on #124, (quote from Gil based on actual measurements of #124)
4. B+ is 440VDC on the 6L6 plates, which seems low. The remaining plate voltages are: V1A and V1B approximately 190VDC each; V2A and V2B 10 volts higher; on the order of 280VDC for the non-feedback side of the phase inverter plate, and about 10 volts higher for the feedback side.
The amp's power supply caps were changed after these measurements and the resulting measurements are not available. Also, Gill posted he did not hear the amp after the re-cap.
talbany
Post by talbany »
Here is the final version of #0124 with some specs Gill posted..
Thank Martin and ic-racer for getting the project going..
If there are no more revisions I'll be glad to post the JPEG and Visio in the files section.. Enjoy
Tony VVT Amps
moj067
Post by moj067 »
Well done and many thanks to those whom worked on this layout , this should now be in the files section for easy access. hint,hint.
Hi Tony,
Since you've left the door open a crack, I'll make one last suggestion that you add the second grommet for the choke and OT primaries to come through the chassis, and move the OT primary wires from the existing one over to it. That should avoid some confusion for a relatively small effort (I think... I haven't used Visio!)
It looks really great, and I like the added text.
MPM
talbany
Post by talbany »
Updated.. and the door stays open!!!
ic-racer
Post by ic-racer »
Another little thing. The manual OD and PAB switches are upside down.
ic-racer
Post by ic-racer »
That low-voltage transformer as drawn would deliver 12 volts to the voltage doubler if it is labeled 6-0-6v. Should be labeled "3-0-3v" so as to provide 6 or 6.3v to the voltage doubler.
Nice layout.
But,
On the second relay you have the B+ power going to the anode of the diode.
mat
Post by mat »
Are the .01 caps wired properly on R/J switch ?
Thanks for the great layout !
mat
talbany
Post by talbany »
Thanks for the look over updated again.. Switches were wired as per Gills drawing..
T
ic-racer
Post by ic-racer »
Getting better all the time!
ic-racer
Post by ic-racer »
mat wrote:Are the .01 caps wired properly on R/J switch ?
Looks like he is correctly showing them in series.
mat
Post by mat »
Yes, talbany updated the picture. On the old one You can see what I meant - one extra wire.
mat
ic-racer
Post by ic-racer »
Here is another little one. The ground for V6 should come from the 50/100 switch and wind up at star ground #3 (not #2 as shown).
ic-racer
Post by ic-racer »
Also, to match the #124 schematic, ground #2 should be the star ground between V4 and V5 (not the sent/return jacks, as indicated).
