Like kitchen cabinet handles or the like.
There are hundreds of designs out there, you just have to pick one.
No I am not braggingYeah? Well, now you're just bragging. Wink
 I am just saying it is possible to get the amp quiet.
  I am just saying it is possible to get the amp quiet.Did this. Thanks, Phil. See photo.Phil_S wrote:Do I see the mains (green/yellow) ground sharing it's ground point with the circuit ground? IMO, that is a sure fire way to introduce 60 Hz or other hash from the house wiring...Please fix this, even if you do nothing else.
What?!? I've moved the mains ground to it's own lug, but I don't see how this made any difference to "bypassing the fuse and the PT." Please explain.Phil_S wrote:It is also unsafe because now your circuit is directly connected to the mains, bypassing the fuse and the PT. You must give the mains ground its own private ground point.
Phil, I still want to reduce gain in input stage and maybe in PI, but I didn't understand your suggestion. The input stage's cathode is grounded, so that leaves the voltage at the plate as the only element that can be adjusted, right? The resistor there, connecting the plate to B+2, is 220K, and I read about 90vdc at the plate. Doesn't it make sense to increase the value of that 220K resistor in order to lower voltage and thus gain?Phil_S wrote:To lower the gain on the input tube, lower the value of the plate load resistor and/or increase the value of the cathode resistor, and/or lower the value of the grid leak resistor.
The mains ground wire is a redundant neutral. It performs the same function as the white mains neutral. It is a "return", so to speak, for the hot wire. There is all manner of mayhem and mishap possible in an electrical device, most of which can't be predicted -- we call these "accidents." They often take the form of a short. One possibility is there will be a backfeed. With the mains ground directly attached to the circuit ground, it is possible the ground will become live and then the fuse is last in line, not first.xtian wrote:What?!? I've moved the mains ground to it's own lug, but I don't see how this made any difference to "bypassing the fuse and the PT." Please explain.Phil_S wrote:It is also unsafe because now your circuit is directly connected to the mains, bypassing the fuse and the PT. You must give the mains ground its own private ground point.
I'm a little out of my element here. I am an amateur, not an EE, so I'll do my best, but don't take it as the absolute truth.xtian wrote:Phil, I still want to reduce gain in input stage and maybe in PI, but I didn't understand your suggestion. The input stage's cathode is grounded, so that leaves the voltage at the plate as the only element that can be adjusted, right? The resistor there, connecting the plate to B+2, is 220K, and I read about 90vdc at the plate. Doesn't it make sense to increase the value of that 220K resistor in order to lower voltage and thus gain?Phil_S wrote:To lower the gain on the input tube, lower the value of the plate load resistor and/or increase the value of the cathode resistor, and/or lower the value of the grid leak resistor.
Phil, the mains ground is typically connected to the circuit grounds via the chassis even if it has its own mechanical (and electrical) connection. The isolation is maintained because the neutral and the mains ground are independent paths to earth ground. The cardinal rule about the mains ground being made with an independent connection is intended to minimize the posibility that that connection will ever be compromised. It's true that the primary and secondary circuits will be connected at the mains panel, but this is the means by which the chassis will be held at ground potential in the event that an above-ground potential becomes connected to the chassis. It is possible to lift or even completely isolate the circuit grounds from the chassis, but that is not common in guitar amps.Phil_S wrote:When you connect the mains ground to the circuit ground, you are, in essence, connecting the primary and the secondary windings. There is, in fact, a direct path created between the two windings when you do this. However remote the possibility of an accident, you've defeated the isolation of the primary and secondary windings.
Which is the bypass resistor? Parallel to the cathode bypass cap? If I reduce this value, I'm making a LARGER voltage differential between cathode and anode, increasing gain, right?M Fowler wrote:decrease the gain of the tube by reducing the bypass resistor
Hmm....OK, sorry for posting mis information. Would I be wrong to think putting circuit and mains grounds on the same bolt is a way to introduce hash from the mains?martin manning wrote:Phil, the mains ground is typically connected to the circuit grounds via the chassis even if it has its own mechanical (and electrical) connection. The isolation is maintained because the neutral and the mains ground are independent paths to earth ground. The cardinal rule about the mains ground being made with an independent connection is intended to minimize the posibility that that connection will ever be compromised. It's true that the primary and secondary circuits will be connected at the mains panel, but this is the means by which the chassis will be held at ground potential in the event that an above-ground potential becomes connected to the chassis. It is possible to lift or even completely isolate the circuit grounds from the chassis, but that is not common in guitar amps.
Well, given that elevating the circuit ground is a way to reduce such noise, connecting it directly to the mains ground would leave the lowest possible resistance between them, but I don't think that the fraction of an ohm resulting from putting some distance between them on the chassis would make a huge difference. Kind of a moot point, the mains ground is supposed to have it's own dedicated attachment anyway.Phil_S wrote:Would I be wrong to think putting circuit and mains grounds on the same bolt is a way to introduce hash from the mains?
