RJ Guitars wrote:GainMaster wrote:...No stinking volume knob here... Brian
I suppose with a name like "gainmaster" we should have known... great job! can't wait to hear it. If you've got a full or partial set of layout and build notes I'd like to follow suit. I really love these low watt amps but I don't think I've got one that has the bloom at the level your talking about. Good work!
rj
No build notes as everything worked out suprisingly well except for the tone stack.  I used the schematic and layout Cliff drew up and the tone stack did nothing (Cliff said I must have screwed it up
 ).  Minor rewiring to match the standard Marshal wiring and it worked like a charm.  Cliff will be doing a final schematic and layout soon.
The amp has virtually no clean on the dial.  The output section goes into distortion very early but stays in control and doesn't get farty or mushy even at the highest gain settings.  From 1/2 to 3/4 on the volume it cleans up real nice with vintage wound pickups.  Overwound and hot pickups would require tweaking of the 150k resistor between the second and third stage.
The blooming everyone is looking for seems to be coming from sympathetic ringing from other strings on the guitar.  My experiments with high gain amps has indicated that lower guitar strings vibrate at the same frequency as lead notes.  Given enough compression and gain, this is picked up and amplified at the same volume as the original note.  Too much compression and gain and the vibration goes out of tune and just sounds like feedback or squeal.  The amount of compression and gain needed seems to vary between guitars.  Different woods, bridges, and pickups will all affect this.  Ken was able to consistently find the right balance for his customers.
I have been playing through a Mass (yes I know it is only 2 watts) and that also affects the blooming.  A certian amount of interaction between the guitar, pickups, and speaker is also needed to get really good blooming.  Unfortunately, I haven't been able to do any full volume testing yet.  The point is that everyone will have different results.  I am certanly happy with mine.
Now, on to experiments with running veneer through a laser printer.
Brian
