Ron Worley wrote:Dan- I have the heater center tap grounded....  what do you mean specifically by "lift" the tap??  Just want to be clear....
I think you mean to lift the heater circuit by grounding the center tap......
Ron
I meant to disconnect the center tap of the heater circuit from ground. But if you don't have a 100 ohm resistor between each leg of the 6.3VAC winding then you don't have an artificial center tap. I thought you did. KF did in Francisca. Leave the heater CT conneced.
https://tubeamparchive.com/viewtopic.php?t=5047
In the whole gut shot you have what appears to be a diode from pin 1/8 (grounded) to pin 3. The blue/brown connected to pin 3 are the OT primaries. Is that what I see?  I'm just suggesting that for now, take that diode out of there. It is not essential and besides KF used three 4007s in series and ran them to chassis. Also, asked before, are the grid stoppers pointing straight up with leads from the board attached at pin 5? That would be fine except I don't much care for grid leads resting in direct contact with a wirewound screen resistor, this can lead to direct feedback and nasty current drawdown. Anyway, said screen resistor is between pin 4 and pin 6 correct? That's OK and then the red/yellow from the PS board connects to pin 6.
Now, move over to the power supply board. As a temporary measure, disconnect the yellow PT primary wires from your high voltage diode strings. We do want to rig it so that the bias supply remains connected. You can accomplish all of this buy disconnecting the cathode leads from the first diode in each high voltage string. OK? Now you've got bias, and you've got filament voltage. Also, while we're at it, on the main board, for now, on the 4th turret at the top to the pot, you have a yellow wire. Pull that away from everything so that it really is in free air. You'll tune the amp with this wire once we get it going. Report back
Dan
