For the Plate resistor quandry:
What I'm talking about is doing two things and then comparing.
1) Measured at the TOP of each of the plate resistors (which gives you B+5, B+4, B+3, which matches whats coming off the power filter caps -after- the dropping string). V1a and V1b share the same B+5 feed. Then measured the voltage of all four plate resistors at the bottom, which is connected to each corresponding plate socket pin. Subtract and you get a per-triode difference between the B+ feeding the plate resistor and the plate.
2) Measure voltage directly across each plate resistor.
Comparing 1) and 2), they aren't the same values.
For instance, in the most extreme case,
Top of V2 plate resistor measures as 295V, which does match the B+ at the filter cap.
Bottom of V2 plate resistor measures as 250V
Difference is therefore 45V
Measure directly across that V2 Plate resistor, one probe on one lead of resistor and other probe on other lead, and I get 25V !! Consistently. 20V is disappearing.
This is eerily similar to my initial problem of extremely low volume.
Glen:
Sometimes I think it is a solder issue. When it hit the "zone" yesterday, I suspect either the bad joint or the bad component was still hot from being reheated and conducting like it should. When it cooled down, bam, back to where it was. Or I could be making this up. Cause and effect is so tenuous at times. Hahaha,
Thanks. Really appreciate your thoughts and will try some of your suggestions.
