Why do you think that? It looks to me like V4&6 will idle much hotter. Where do you think they get their bias voltage?
https://el34world.com/charts/Schematics ... 33_212.pdf
Yikes it’s got a switched mode power supply!
This still doesn't negate my point. "very good sounding" isn't the same as "my favorite"roberto wrote: ↑Mon Nov 30, 2020 11:06 amCrate Vintage Club was one of my first amps and I have to say it was very good sounding. They have build few very good amps and alot of cheap not-the-best stuff.pompeiisneaks wrote: ↑Mon Nov 23, 2020 3:04 amI don't know I've heard of anyone claiming the tone of their crate was their favorite amp.
I think I'll repeat here that you've made it clear you liked it, but nowhere did I see you say it was your favorite amp. It can be very cool/good in a few very specific use cases...AmpAwe wrote: ↑Mon Nov 30, 2020 12:35 pmYes - Some Crates have pretty respectable tone, but still get no respect, which is OK by me. A guitarist in a popular Denver band demoed the Crate 32 for me at GC - he played the gain channel with boost on at about 8.5 volume with a Les Paul - The V32 has a pretty great sound like that - a bit of a one trick pony, but you know if the trick is a good one, then it is pretty great. So I bought one. The V33 is really very similar to the V32, but Crate changed it enough to really mess it up. Thing is the V32 would overheat and burn out the input diode (i think that was the component), a really well know problem. I have taken the top grill plate of to give it more air flow, for better cooling - the suggested fix is to get the diode up off the circuit board to prevent the problem, I should maybe do that.roberto wrote: ↑Mon Nov 30, 2020 11:06 amCrate Vintage Club was one of my first amps and I have to say it was very good sounding. They have build few very good amps and alot of cheap not-the-best stuff.pompeiisneaks wrote: ↑Mon Nov 23, 2020 3:04 amI don't know I've heard of anyone claiming the tone of their crate was their favorite amp.
SO ANYWAY just found something out about this Crate V33, been messing with. I took out v5 & v7 - and "OH - I LIKED IT!"
After lots of pre-amp tube changes, I settled on JAN-GE's in v1,v2,v3 and “Reflector 6P14P” in v4 & v6. And the sounds WAS inspiring for me! Which is what I need to play and hear NEW sounds to play better than usual AND to play NEW things I have not played before - just because the sound is inspiring!
I don't think it will hurt the V33 to use it without v5 & v7. But the CAB I used is a 16 ohm where the V33 only has 8 ohm outs. So I need to find out if it is going to be OK to run it like that, because I want more of that!
I read it on the web - and did not see a challenge to running with 2 power tubes on the v33 - there was a comment to not pull from the same side, saying that could unbalance the OT and stress it. After playing it for 20 - 30 min I check it for any heat and everything seemed cool, but i did not check inside the chassis. I would have never tried pulling half the tubes, but 4 reading several, of guys doing
Well Thanks for that revelation – your info led me to read and learn where its cathode resistor is. I am trying to learn to read schematics – that V33 schematics cathode resistor is #R94 is its value 82 ohm? 7 watt. Seems odd to me there is no omega there.martin manning wrote: ↑Tue Dec 01, 2020 1:50 am Well, you can't believe everything you read on the internet. The author of that article failed to notice that the V33's power tubes share a common cathode bias resistor.
Yeah OK - point noted. I appreciate you posting a follow up, to repeat the comments, reading them again, I can better appreciate them even more.
Most of us are doing the same here. Just imagine that still now, after all the decades that passed since the first triodes started singing and after all the decades that passed since the first vacuum tubes became obsolete, people are still inventing new ways to improve their working conditions. Very few people worldwide can say to master the argument.
Question of scalar tone aside, is there any research on a decent number of tubes of different producers (not brands, but producers)? EG, what I've noticed is that JJ 12AX7 are usually more sensitive to grid stoppers (higher Cga?). This is something I cannot measure, but based on many comments also from other people, it seems a common feeling they give. Is there any analysis like that, fully available online?
