Or just swap the labelsluckey wrote: ↑Fri Jun 21, 2019 7:15 pmThe connection to the reverb FS must be shielded but the connection to the trem FS does not have to be shielded. So, if you have a typical Fender two button FS, you need to swap connections at the FS end. May be easier to just swap the switches around.norburybrook wrote: ↑Fri Jun 21, 2019 6:02 pm The footswitch is working in reverse fro the reverb and trem but if I switch the cable connections at the amp end it makes a horrible noise and stops working.
Or, you could swap the connections INSIDE the amp if your layout permits.
 everything else on this amp is the wrong way round so why not the switch
 M
