ampgeek wrote:
....I read through this thread and it reminded me of a very sweet but old Silvertone I had on the bench a while back.  The noise symptoms were, as best as I can tell, identical to yours.  Persistent (but intermittent) snap, crackle, pop, surfy-waves and a constant back-ground of bacon being fried off in another room kind of sound.
I judiciously replaced, one by one, the 3 or 4 components around the first stage that could have been problematic...to no avail.  The only possibility that remained was the old phenolic(?) tube base.
Dave, cautiously optimistic here, but I may owe you a beer......
Went home last night after contemplating your post......I had a 9-pin ceramic socket.....so I wired it up.  (I am not very fast....took a couple of hours to do the swap).
Following the tube socket swap, I fired up the amp.  The *noise* was there initially -- though not quite as loud -- for about the first 30-60 seconds.....then the offending "snap, crackle, pop, surf-wave, distant thunder" sound just faded away.  I continued to play the amp for about half an hour, and the noise issue never manifested during that time......the amp seemed to do exactly what it was supposed to do, and sounded pretty decent.  Wow.....could it be that it was somehow the
socket after all this hunting?
I have a few more minor lead dress things to address before I button this amp up.  I expect to play it a little more to make sure that the issue has been sorted out, but I am really hopeful that the issue has been solved by this.
Thanks again -- very much -- for sharing your Silvertone observation with me.  Further updates as I get there...
