Has anyone verified this yet?Re using a tube rectifier, it's a class-A amp, so the average current is constant, i.e., no increase to produce voltage sag.
I accept that's the theory but reality will inevitably differ, if only because the theory ignores overdrive, which tends to be a key part of guitar amp usage, even for ostensibly clean tones.
From static to max square cranked, my guess is that the current draw will increase a fair bit, eg 25%.
It will vary according to the particular amp, eg operating conditions (eg biased hotter or colder than mid point), whether the power tube is a pentode or beam tetrode, how saggy the plate and screen grid supplies are, signal asymmetry when overdriven in earlier stages.
At the weekend I found a virgin transformer set and chassis that I bought over a decade ago for an SE EL84 amp, and had totally forgotten about.
I'll put it together sometime, honest, and make my own measurements, but in the meantime would be grateful if someone could check their amp?
Pete
 mods were re-evaluated!! I should repeat the tests sometime.
