Hi,Ravie wrote:Bringing this thread back from the dead as I've just now finally had some time to mess with this amp.
I replaced:
- Bias resistor with a 33k in place of it's 27k.
- V8 Power Tube Socket with brand new
- Capacitors at positions 27, 28 (104's)
- Resistors (which I blew messing around like a frustrated bull months ago)70, 71 (They feed pins 2 and 7 off the PT)
- New Sovtek 5881's (I was going cheap in case I mucked it up again)
I've gone over the schematic with a fine tooth comb and all of the wiring is now as it should be.
I went to bias the beast, with the bias pot turned all the way down as it should be before beginning, and when I flip the power switch it's NOISE CITY even with every potentiometer on the front turned down to zero.
The reading at the bias resistors with the bias pot turned all the way to the left (down) is .044 and .043mV which is still WAY too high.
I don't get it.
Here's a video. Pardon my rambling.
http://youtu.be/G1eQPlac-sM
Some random thoughts off the top of the knoggin:
What are the voltages without the tubes?
Is there noise without the tubes?
Is there noise without a Guitar plugged in?
Have you tried the new Sovtek 5881 in another amp first?
Have you cleaned the pots and checked if the input jack is grounded properly?
You shouldn't have much if any signal with pots turned to zero.
Others will add their input.
Best regards,
Steve
PS My last post prior to thread's hiatus was about starting from scratch. I worked on a Fender Super 60. I found besides the evidence of prior repairs, a resistor burnt up. Simple repair to fix the OD that didn't work. I checked over the PCB to determine why the component failed. Everything checked out. Then fired up the amp, another resistor went up in smoke! It took out the 6V3 heater winding on the PT!
So now I am out a MC PT, and the darned amp was still an issue. So I Gutted the amp, and built a Super Reverb black face circuit (what the owner originally wanted but couldn't afford), and offered the owner a choice, try the amp out, if you don't like it, let me purchase the amp for the price you paid or if you do like it pay me the original agreed upon repair charge.
Sound crazy? I actually made more money off the deal (he kept the amp) and was referred to build other amps. After that I changed my policy, no PCB amp repairs. It Wasn't Worth The aggravation. However my other electronic business took off, but that's another story.
