Turrets
EL34
Re: Turrets
Post by EL34 »
if u know where to get them - spill the beans dont keep it a secret
lol, the post right above your 3 post
yo cbass, what's up
10thTx
Re: Turrets
Post by 10thTx »
Hoffman carries excellent quality turrets at a very decent price such as .15, .13, & .11.
http://www.hoffmanamps.com/MyStore/perl ... =629196441
With respect, 10thtx
EL34
Re: Turrets
Post by EL34 »
thanks 10thtx
Been selling the same turrets from the same source since the 1990's
always excellent plating and solder adhesion
I even have a batch of silver plated turrets here if anyone needs them
I don't have those in my catalog
mark enger
Re: Turrets
Post by mark enger »
1+ for the hoffman turrets, and his eyelets are great too, I've also bought turrets from ebay from china 500=71$ shipped for giant double turrets but i've found two different sizes in the same batch and other odd things like a half turret, non chromed turrets, A large batch of standoff is my next need mine are running low anyone know where to order a large batch from?
Smokebreak
Re: Turrets
Post by Smokebreak »
Phil_S wrote:
I found for about $10 you can buy a real generic turret board: http://www.tubesandmore.com/products/P-HTUR-60 I used one of these in my last build and liked it a lot better and it is worth the extra few dollars. Because it has lots of unused holes, I was able to add a few turrets in key locations to make it more suitable for my needs. Of course, YMMV.
This is what I've been doing as well. Does anyone know where to get the same type thing, but with eyelets? I know that a lot of folks sell eyelet boards for specific circuits, but any generic ,say, 30x2rows out there?
Btw all this stuff is on sale right now at AES
EL34
Re: Turrets
Post by EL34 »
Besides Turrets and eyelets you can also use terminal strips and a new item I just started stocking, Tag boards
Just pry up the tabs and solder away
Board building supplies - http://www.hoffmanamps.com/MyStore/catalog/parts12.htm
[img:1200:253]http://www.hoffmanamps.com/MyStore/cata ... G_7385.jpg[/img]
[img:728:437]http://www.hoffmanamps.com/MyStore/cata ... G_7172.jpg[/img]
[img:900:830]http://www.hoffmanamps.com/MyStore/cata ... G_2369.jpg[/img]
Re: Turrets
I buy from Hoffman and Turretboards.com just got this info in today's email from Turretboards. SPECIAL BLEND OF SPLIT TOP TURRET
SAME AS DOUBLE TURRET BUT IT'S A SPLIT TOP
http://www.turretboards.com/
briane
Re: Turrets
Post by briane »
after 50 builds or so with turrets/eyelets/combos - Ive come to prefer eyelets.
that said I use both - eyelets for most stuff, turrets for power connections, relays, stuff to hook up later, or components I want to put 'out of plane' with the rest.
they both have a purpose - 1 doesnt sub for the other when it comes to convenience of tuning the amp. exelets are cleaner, quicker to build with, and more compact.
Milkmansound
Re: Turrets
Post by Milkmansound »
M Fowler wrote:I buy from Hoffman and Turretboards.com just got this info in today's email from Turretboards. SPECIAL BLEND OF SPLIT TOP TURRET
my pulse quickened when I read this email today as well. Going to integrate them into my amps as soon as I run through my current stock of double turrets. Sweet!
Re: Turrets
I was thinking I could now use 3 different size turrets and several eyelet types to keep things wired nice on my boards, you know that layered look. :)
73GTV
Re: Turrets
Post by 73GTV »
randalp3000 wrote:
Phil_S wrote:
EtherealWidow wrote:I'm using a terminal board like this on a build right now. https://taweber.powweb.com/store/longboard.jpg
Not too bad, although the filter caps don't fit on the two inner terminals. Other than that, I haven't run into any real problems...yet. Still just mounting components, though.
I was using boards like the one from Weber and they are just OK. I think they are not as nice as a real turret board. (Also, you can buy the same board on eBait direct from China for half the price, postage included.)
One thing I don't want to do is drill and stake my own board. The fiberglass is supposed to be carcinogenic if you breathe it in, and I don't have the proper dust collection system to be working with it. Once in a while I drill an extra hole keeping the drill at slow speed to control the flying dust. It is wise to wear a proper mask when drilling.
I have a few of those and they are quite nice. They have the 2mm and 3mm turrets as well http://www.tubesandmore.com/products/S-HTUR-B
and blank boards in 2 and 3mm http://www.tubesandmore.com/products/P-HTUR-C
don't waste your time on the cheap boards http://www.tubesandmore.com/products/P-HTUR-A not very good
I Agree, the P-HTUR-D (Blue), P-HTUR-E (Green), and P-HTUR-F (Yellow) are very good boards, 189 holes and sized at 258 x 60 x 2mm. These are good boards, however the P-HTUR-A cheap board for $2.95 are bad because the two outer holes are the correct size, but the middle section of holes are damaged in production which is why the cost is so low for them. Just thought I would chime in since yesterday i had my boards delivered and they are in front of me as I post this statement.
I also have that Black board from China from Ebay for about $10.00 bucks which has a nice painted surface, but are longer than the those boards, 300 x 60 x 2mm. The turrets from China (2.60 mm) will fit both boards however the ones from Antique will not fit the boards from China. (2.90 mm wide)
(I Just measured each turret.)
Re: Turrets
I use these boards a lot: P-HTUR-D (Blue), P-HTUR-E (Green), and P-HTUR-F (Yellow) and the red boards. I think the red board is thicker.
I have to drill out all my holes as I design the layouts. But I'm so used to it that I don't even think about it much anymore.
I need another burnt out motor drill press for cheap so I can load one drill press for eyelets and the other for turrets. I get lazy.
Re: Turrets
yo cbass, what's up
Hey Doug Hows your 'Maters?Mine are just now startin to through a lot off.Bout two months behind last year.
Last year I could have put my plats out in Feb.This year we had a snowstorm in the middle of May.
EL34
Re: Turrets
Post by EL34 »
excellent mater crop this year
bal704
Re: Turrets
Post by bal704 »
"I Agree, the P-HTUR-D (Blue), P-HTUR-E (Green), and P-HTUR-F (Yellow) are very good boards, 189 holes and sized at 258 x 60 x 2mm. These are good boards, however the P-HTUR-A cheap board for $2.95 are bad because the two outer holes are the correct size, but the middle section of holes are damaged in production which is why the cost is so low for them. Just thought I would chime in since yesterday i had my boards delivered and they are in front of me as I post this statement."
I've never noticed problems with the center section of the cheaper boards. I only use eyelets, never turrets. Just push them in, and use a tool to swage them.
