6G6B build done
Re: 6G6B build done
In my build I changed the bass channel into a wreck k50 preamp - the circuit is quite similar. the 6g6b cleans up a little better in my amp, but the k50 sounds better
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
Re: 6G6B build done
Just a follow up, I delivered this Bassman in a new blonde head cabinet about 3 weeks ago. The customer is just loving it with his Tele and LP. He's loves the bass channel with the LP and his Tele with the normal channel.
TM
TM
Re: 6G6B build done
TM,
What changes did you do to the Bass Channel other than these?;
Bass chan vol - 250KA stock value
Bass chan Bass pot - 100KA w/ 3.3K tail
Bass TS stack - .02, with all Bass chan couplers changed to .02
Bass slope - 43K
TS cap - 330pf
PI= 750 and 8.2K tail
Bass cathodes - 4.7uf
Gridstoppers - 6.2K
no treble bleed on V2b
Bass slope - 43K
TS cap - 330pf
Gridstoppers - 6.2K
Re: 6G6B build done
A recomendation to anyone building the 6G6B, always use a high quality Silver Mica PI Input cap rated for at least 500VDC (Cornell Doblier) or expect trouble as this is one of the Direct coupled fenders and the cheaper SM caps don't hold up!!!
Re: 6G6B build done
Thanks for the tip.marshamps wrote:A recomendation to anyone building the 6G6B, always use a high quality Silver Mica PI Input cap rated for at least 500VDC (Cornell Doblier) or expect trouble as this is one of the Direct coupled fenders and the cheaper SM caps don't hold up!!!
