jezzbo wrote:Thanks for helping Mark.Mark wrote:So if you use the bulb current limiter and plug your guitar in to the jack can you get a sound out of the speakers?short circuit somewhere in the amp
Have you tried a different power transformer?
That is to say use a wire with alligator clips to go from the rectifier diodes of one amp to the filter caps of the other amp.
The preamp tubes don't present much of a load for the power transformer, the output tubes do. The output tubes heater current alone is 1.8A or 11.34 watts. The preamp tubes use 1.8 watts in total.
If you think the problem is in the output stage try disconnecting the primary leads to the power tubes, tape the output transformer primary leads up so they are well insulated.
See what happens next.
Good idea about pluggin in a guitar and hooking up some speakers.
I will try that as soon as the amp is wired up again.
About "disconnecting the primary leads to the power tubes" I will try too.
I have not yet tried a different PT.
This one is a brand new one (from tubeampdoctor.com)
Probably somewhere this weekend. (busy week at work)
Thanks again, I'll keep you posted.
Jesse
Since all else is fine I would suspect the filter supply at this point. If you are sure your rectifier is good too. I did not read if your amp actually blows fuses or if you tried playing through it as is.
