418P capacitors???
diagrammatiks
Re: 418P capacitors???
Post by diagrammatiks »
no problem using what was originally used when going after a particular sound or cloning an amp.
it's a far stretch to say that continuing to use those parts is some how innovative.
polyester caps were used by guitar amp builders because they were cheap.
they still are cheap.
renshen mentioned paper/oil caps...a good difilm paper/polyester/oil cap is comparable with a mkp/kp which is way small value oil caps were phased out.
LeftyStrat
Post by LeftyStrat »
Colossal wrote:
martin manning wrote:An example of... well it's really an example of several things. You'll lke this, I think, Max! http://www.npr.org/blogs/deceptivecaden ... -the-strad
Loved the Chapman stick, BTW!
Martin,
Great article! Of the two clips, I picked the Stradivari which I found interesting. That said, I like new guitars, metal film resistors, and polypropylene :lol:
I listened to both, and thought there was a nice low midrange emphasis that the second had over the first. Where do you click to find out which is which?
LeftyStrat
Nevermind, I read the rest of the article.
LeftyStrat
But this should show up on a frequency response analysis right?
renshen1957
Post by renshen1957 »
Max wrote:Steve, I didn't write invention but development, and I didn't write performers but musicians. And to initiate and fuel development, IMO new instruments have to be implemented by musicians into the daily life of the world of music. And this implemantation only takes place if musicians (performers, composers, conductors, etc.) gladly welcome these new tools because they are different from what they are used to - instead of complaining about this.
Max
Hi Max,
Point well taken. By and large some musicians are pioneers, and where guitarists are concerned, pedal and FX have made the most in roads.
The Beatles who incorporated and exploited new sounds from Transistors Amps, ethnic instruments, an sampled keyboard, a variety of electric keyboard instruments, harpsichords, although not the first (the Doors used it before the Fab Four) a Synthesizer on their last recorded album did push the envelope and raised the bar for others to follow. They weren't afraid of new technology, but didn't abandon the tried and true, either.
One can be eclectic.
As to components, it doesn't mean that you can't achieve the same tones with other parts than HAD had used even though it would be easier to use the same. I don't use the same metal film resistors as Dumble or the same caps, if you listen and follow the tonal prototype to best of one's ability very good results can be achieved. One use polypropylene caps, but it may require additional parts and circuit changes to compensate. Will the amps be equal Dumble? In my case most likely they won't, but these efforts will departure points for new and different amps.
Happy Chinese New Year,
Steve
