This time the amp was set with almost all EQ's at noon, except the bass, which was at 0. Bright volume at 10. Sounds a bit smoother than the previous clip and i think i prefer this tone a bit. Recorded with an Epi Les Paul:
http://soundcloud.com/vintagecharlie/jt ... i-les-paul
The balancing resistors are the same what can be seen on dual filter caps in later Marshalls? - 10k 1w on the preamp dual 32uF cp and 47k - 56k 2w on the dual output cans, or is it something different?
Yes, the output filtering is as you guessed, but i'd resort to increasing the filtering or henries of the choke as last option - i love the squishiness of the amp, when it's dimed and higher filtering would probably make it a different animal.
