	Moderators:  pompeiisneaks , Colossal
								rogb
		Posts:  1094  		Joined:  Fri Apr 02, 2010 9:56 am
						Post
								by rogb   »  Mon Jul 05, 2010 1:57 pm
			Tom, I am getting my (not too brilliant I know)  TC G Sharp FX soon.
Your parallel loop mod has got me thinking that is this going to be the best way to get this to work with my Dlator?
I know people rave about the Suhr Minimix, will your parallel switch give me the same effect(
If so then you have just saved me a load of money
		Posts:  15446  		Joined:  Wed Oct 17, 2007 1:01 am
						Post
								by Structo   »  Mon Jul 05, 2010 4:51 pm
			Well first of all it isn't my design or idea.
Several people here thought of this, I just made a layout for it.
I tried an earlier version of it and didn't care for it.
It really depends on what effects you are using and how their signal plays with the loop.
It's pretty easy to mod your existing loop to make it parallel.
Then if you don't care for it, revert it back.
With an effect like the TC you may be able to adjust the line level and other settings that will make it work better in a parallel loop.
								rogb
						Post
								by rogb   »  Mon Jul 05, 2010 5:17 pm
			Thanks, I'll give it a go, as you say, easy enough to try.
EDIT: I have read up on the other work done on parallel loops by TAG members, so my thanks to them too.
The G SHarp has a "kill dry" switch, which should help in parallel operation.
I look forward to giving it a go.
Cheers
Rog
