did some valve rolling and ended up with all new JJs in the pre amp. I also tried a 12 AX7 in the PI which i preferred. So with that in mind I've made the whole PI section now like #183 with the exception of the 820R-24k-390 which is close on my amp with 800R-22k-390R adn the prescence is still a 2.2uF rather than a 1uf.
I'm liking the sound of this better now. I would say in OD mode there's slightly better note definition and its a bit 'sweeter' and seems to have a bit more dynamic range with the guitar volume control.
So in some way's the amp is now like a #183 with 2nd gen low plate OD. The EQ is 'nearly' Skyliner ,1M bass instead of 500k and 500k Treble instead of 250k so it would only take a few resistors and 2 pots to turn it into a full #183....
However, I'm liking how the OD sounds and the fact you can't tweak it in some ways is good so I'm leaving it as it is, a new kind of hybrid
 (edit) I'm loving the PAB on clean with this amp, it's giving it a lovely crunchy, sparkly tone that gives a Strat a nice SRV type thing. The FET also does this but in a slightly different way.
I shall post some sound clips as soon as i can.
Also made a single cable send and return today from Van Damme Star quad and some nice sleeving i bought
 M
