Supplier for 1/16" thick wood for faceplate
FunkyE9th
Re: Supplier for 1/16" thick wood for faceplate
Post by FunkyE9th »
Structo wrote:Do you hammer the punch or press it with a drill press?
BTW, thanks for the info. :D
Hammer
Distortion
Post by Distortion »
I use a unibit..
You need a drill press but it is quick and accurate.
It takes about 3 minutes to drill all the holes..
[img:320:320]http://www.irwin.com/irwin/consumer/ima ... 101_lg.jpg[/img]
Distortion wrote:I use a unibit..
You use that on 1/16" face plates?
Chad
Post by Chad »
Thats a nice looking unibit.What brand is it and where could I get one. Thanks, Chad
mclmk8d
Post by mclmk8d »
That actually looks good; do you clamp it close to the hole for stability on a 1/16" faceplate and use some wood underneath?
Tom, that's my guess.
Where gators roam the backyards; keep your kids and dogs inside!
mclmk8d
Post by mclmk8d »
Chad,
It's an Irwin Unibit 1T...google it...lots of places, including fleabay; even Amazon has it.
Chad
Post by Chad »
Thanks mc. I'll check it out.
Distortion
I clamp a thin piece of scrap wood to the drill press table and the extra wood acts as a support for the thin faceplate.
Another thing that helps is to use a spring loaded punch and punch the center of each hole.
The easiest way for me is to have a spare chassis and clamp the faceplate up to the front of the chassis. I then use a mechanical pencil and scribe the holes on the faceplate. When you remove it I then use the punch to mark the center of each hole.
The center punch is is used as a basic guide.
This is the quickest and easiest way to drill out faceplates that I have found..
