Bias reading not stable
Bob-I
Re: Bias reading not stable
Post by Bob-I »
UltraHookedOnPhonix wrote:Bob-I
The B+ current rating is 345-0-345 @ 200mA
That should handle a 50 watter just fine. If the voltage is dropping something else is causing it. Next I'd look at the filter caps.
UltraHookedOnPhonix
Post by UltraHookedOnPhonix »
The filter caps were recently replaced with Sprague Atoms although I can't rule out a premature failure. How do I check for a leaky cap? I read somewhere that you could use the resistance setting on the DMM to check.
Thanks again Bob-I!
