Copper Grounding Bus
- Ron Worley
Re: Copper Grounding Bus
Tim-
I may have another source and Allyn said that he might have some... but in the end, I may have to suffer Ampwares..again..
Thankfully, my missus doesn't seem to mind me doing this stuff...keeps me out of her hair, I suppose....
Alan- Thanks very much for the grounding scheme... Do you use pots that have an insulating collar that prevents grounding against the chassis, and where do you get them???
The scheme makes sense, but I won't kid you that I need to read up on star grounds and Aiken's stuff to really get it sussed..
Although this is technically my first real build, I'm a (rusty) BSEE, and I've been repairing Fenders for several years. I have been very anal about lead dress, etc, and baring any real f*#kups, I should be relatively OK. I have read others mention the shielded on the volume pot and a V1 grid resistor to tame instability. I must admit that I am not particularly schooled on tweaking, so I have been taking copious notes from the board. Part substitutions are where my lack of theory mastery really shows.... I figure that's part of the learning process doing this whole Wreck thing... and I love it.
Again, many thanks for sharing your experience with a Noob!
Ron
Ron
In the scheme I mentioned, it really doesn't matter if the back of the pots are grounded to the chassis or not, they are insulated from the pots terminals by design. The idea is not to connect any pot terminal to the chassis including the back of the pot, except at the correct chassis ground point.
- Ron Worley
Alan- I understand- what insulated speaker jacks do you use to keep the speaker ground off the chassis????
Ron
Ron
I've been looking for a source other than Ampwares for those the grounding lugs with no luck so I bit the bullet and ordered from them, just got them today and the delivery time was two weeks. They look OK though the hole for the wire is drilled slightly short of the back of the pot, dremel will take care of that..
- Ron Worley
Allyn didn't have any lugs, but I have another source that is looking good. If that craters.... well, it's off to Ampwares for another exercise in frustration...
Ron
Ron
You can mount 3 isolated stand offs and run the buss wire on thatRon Worley wrote:Bump-- No other inputs guys??
Ron
Only connect to one place at the chassis or put the buss on the board
Cliff jacks will work for that.Ron Worley wrote:Alan- I understand- what insulated speaker jacks do you use to keep the speaker ground off the chassis????
Ron
- Luthierwnc
It isn't the most elegant method but I usually take a piece of 14 gauge Romex and crimp/solder a ring terminal on one end. That is attached at the closest PT lug to the preamp. You can leave some insulation on near the power connections.
This runs behind the pots about 3/4" and is the exact right size to fit in the solder lug of a cliff/rean/neutrik isolated jack where it terminates. Roughing the copper up a little with scotchbrite improves solder flow. Grounds from both the board and controls attach more-or-less along the line according to the related nodes in the power stage (i.e. preamps on one end, main caps nearer the trannie.)
FWIW, Skip
FWIW, Skip
As does some extra flux painted onLuthierwnc wrote:... Roughing the copper up a little with scotchbrite improves solder flow...
Tim
Just ordered a bunch of wire from http://www.wires.co.uk/ - mainly pickup winding but also some 2mm tinned copper for use as a buss - yes 2mm is probably overkill.
This guy has all different gauges but specified in mm.
Hope this helps someone.
- Ron Worley
Thanks for all the great ideas guys. I like the one using a set of isolated standoffs.... but I have successfully found a suitable grounding lug with a long enough lead...
Ron
Ron
- Ron Worley
And I managed to get enough to share with the Forum. See my post in the For Sale section.
Ron
Ron
