Look closely at the EL34s. On my YBA-1A you could see that the screen grids were glowing a dull orange. That's the way it came when it was new. When I replaced the power tubes, I didn't have a chance to play the amp, even at low volume. I just set the bias colder so the screens didn't glow and packed the amp across town to the rehearsal space. When I played it through my two 2x15 cabinets, it sounded horrible. After I adjusted the bias hotter, (I had installed a pot that was accessible without opening the amp) it sounded normal again.GerryJ wrote: ↑Fri Aug 30, 2024 3:00 pm In my YBA-1A Mk II, which does have an adjustable bias trim pot, my trim pot is almost (but not completely) counterclockwise (i.e., allowing lowest cathode>plate current flow, 'cold') and it shows a plate current of 38 mA, which is 81% of assumed maximum dissipation of 47 mA (25 watts/537 V). Playing this quite loud (over 100 dB) but only with a touch of nice warm harmonic distortion, in a dark room the plates stay completely dark, no hint of any redplating whatsoever.
Check what I said about the 470K 2W resistor in reply 10. I'll bet yours will measure high and that will cause you to turn the bias pot almost as cold as it will go. Replace with a 2 or 3 Watt MOX resistor.
