thinkingchicken wrote: ↑Fri Sep 30, 2022 3:45 pm
HotBluePlate seems to be an amp builder, not sure. He said it is due to the voltage that a distortion pedal possessed, something like that.
I'll go look at the conversation. I've heard that rationale before, and I disagree with it. When I discovered it before, (again, not bad-mouthing HotBluePlate, I'll go read the conversation) the rationale went something like "Tubes have much bigger power supply voltage, hundreds of volts, so they can amplify up signal to bigger voltages than pedals with a limited 9V power supply." This is a mishmash of the reality. Having hundreds of volts of power supply "headroom" does mean that you can make bigger undistorted signals. That really doesn't help much when (1) the signal to the speakers is limited to whatever the output watts into the speaker load is and (2) the "gain" is to be used for distortion anyways.
Let's assume that a tube preamp makes a 200V signal. A 9V pedal might make an 8 volt signal. 200V/8V = 25. Converting 25 to db gets you 28db more >>UNDISTORTED<< signal level. So the advantage is to the tube by 28db, right?
Wrong. Voltage swing is not gain, and that's not distortion. The tube circuit and the pedal can have exactly the same >>gain<< but the pedal starts distorting 28db sooner than the tube circuit. One way of looking at this is that the pedal distorts more by 28db.
For a typical 100mv single coil guitar output, +115 db is an output voltage of 0.100V X 562,341 = 56,234V. Neither the tube circuit nor the pedal is going to reproduce that cleanly, so both will distort by limiting or clipping when limited by their power supply. The pedal will distort earlier than the tube circuit and will seem to have more "gain", but really will have just more distortion because it started distorting 28 db earlier than the tube circuit.
If you really want more gain, put a distortion pedal in front of an amp. Now you can get your 100+ db from the distortion pedal and another 100+ db from the amp. Wow! You now have 200 db of gain! Is that better, and if so, how?
No, I'm not familiar with Dunning Kruger phenomena.
It's an interesting concept. I think you'd enjoy reading about it. Wikipedia has a good write up on it. It explains a huge amount of the "experts" dispensing advice on the internet.
Tbh, it does not matter if it ends up becoming a noise generator because I'm trying to experiment with harsh noise "music". As long as the peak decibel gain is beyond 140 dB or more, it is just fine
 it is just this curiosity about how will something with a peak decibel gain of 140 decibel or beyond will sound like. I believe it will sound just like the two videos I recently posted.
Good luck on your quest. The simplest way to do that is to stack a pedal in front of an amp and turn up both gains until you get what you like.
Usually people equating gain with distortion, but this is not always the case if I'm not mistaken.
It is never the case. Hearing someone equate gain with distortion signals that the person doesn't really understand either one.
 But the more gain, the more clipped the waves become because of the limiting headroom. Correct?
In the simplest possible case, yes. But the actual distortion can be achieved by other ways without large power supply headroom, as i explained above. In fact, relying on the power supply voltage for clipping gives tube amps a disadvantage in getting more distortion. There are other, and often better sounding, ways to distort. Distortion is not gain. Gain and power supply voltage is one of many ways to get distortion.
Mark Twain
