Perhaps someone could explain this to me?
Here is a picture of the current limiting resistor installed prior to forming the caps.
The red wire leads from the rectifier and the other leg of the resistor leads to the first bank of reservoir caps.
I'm following bepone's procedure somewhat and there have been no fireworks, nothing to report, it all seems pretty uneventful. So far...
However, I got a 140VDC voltage drop with this resistor, so today, I'll be forming the caps again without it, with full power.
The voltage drop didn't occur after the resistor however, but
before it, at the tail of the rectifier.
First thoughts: bad transformer but then, because the voltage range was around 320VDC coming off the rectifier and one side of the secondary is about the same, I thought I might have a bad diode in the bridge. I tested the diodes. Nothing wrong there. So now, I've pulled out the resistor and voila! I get 460VDC with no tubes. This is some kind of Kirchoff balancing act I'm sure, a consequence of the current the resistor was drawing (but didn't measure, so don't ask). The installation of the 100k resistor, is something I would do again since it offers a measure of protection from inrush current that, at the moment of powering it up for the first time adds peace of mind if nothing else. But now, I should do the procedure again to bring the caps up to the operational voltage. I also measured the output of the secondary HV lines: ~326VAC each which told me that the transformer was okay but after the bridge at the test point, it's DC. Is it possible the voltage drop occurred because of impedance in the DC line??? I understand the ability of impedance to affect the voltage and current flow upstream, but if this occurs with DC as well, appparently, not very well!
