AB165 mod help please!
pompeiisneaks
Site Admin
Re: AB165 mod help please!
Post by pompeiisneaks »
sluckey wrote: Sat Apr 18, 2020 2:43 am
sluckey wrote: Sat Apr 18, 2020 2:22 am Look at the fender wiring diagram and it will all make sense. :mrgreen:
I'm lost....
what is a 'wiring diagram'
~Phil
tUber Nerd!
sluckey
Post by sluckey »
pompeiisneaks wrote: Sat Apr 18, 2020 6:21 am I'm lost....
It was a poor choice of words on my part. I should have said "layout diagram" (which is a wiring diagram). Not talking about schematic. :oops:
Pin 1 was used on ancient 6L6s with a metal case. Pin 1 was connected to the metal can and when connected to ground to act as a shield. Then someone invented glass and the metal 6L6s became extinct and pin 1 was no longer used/connected to anything. Smart folks at Fender decided to simplify their board layout and mounted the 1.5K grid stopper directly on the tube socket. The 1.5K was mounted between pin 1 and pin 5 on the AB165 as well as most other blackface amps. So, the correct voltage to measure on pin 1 of that amp is the negative bias of roughly -45vdc. Having 11 volts (either positive or negative) on pin 1 of that 6L6 in that amp will quickly destroy the output tubes.
So, look at the "layout diagram" and/or this pic and it will all make sense. :mrgreen:
pompeiisneaks
Site Admin
Oh man I don't know why I didn't put 1 and 1 together there, that makes sense too.
sorry sometimes I'm denser than lead :D
~Phil
tUber Nerd!
