The eyelet board layouts I drew up and posted there are designed to replace the JBorders PCB's that went out of production- same circuits and same footprints. The main power supply board is fine for a #124, no mods needed (220u reservoir caps instead of the 300u in the #124 layout, though), and it's easy to convert it to the "Precision" power supply layout by drilling a few more holes. The relay supply board is fine for a 12.6V transformer powering 12V relays. You would need to convert it to a doubler if you are using a 6.3V like HAD did in #124.pompeiisneaks wrote: ↑Wed Mar 07, 2018 4:57 pmThe main board is fine, but all of the rest are nothing like (from what I could see) the boards in #124 and I had to rebuild them all based on the corrected layouts from that board... The ones from this thread: viewtopic.php?f=5&t=29630
Which ODS is "correct" - totally confused!
Re: Which ODS is
- pompeiisneaks
- Site Admin
Re: Which ODS is "correct" - totally confused!
Yup that's what I did, I didn't realize this sadly until I'd ordered the 6.3V power supply and then built the boards
Just was using it as a note to make sure people confirmed they'll work the way they want/need them to.
~Phil
~Phil
tUber Nerd!
