[img:612:359]http://audio.thedelimagazine.com/wp-con ... 12x359.jpg[/img]
Except that a band-pass filter is mirrored and would have a similar roll off on the low frequency end. Sorry was the best image I could find.
In any case, while I'm definitely not opposed to removing the bass control from the circuit, don't be surprised if the issue you're describing doesn't go away once you do.
This among other reasons is a difference between Hi-fi and guitar amp OT's. Most Hifi OT's are rated full bandwidth (20-20khz) while guitar is generally about 150-10khz. The logic on the latter being that the lowest note on the guitar is about 75hz or so (can't remember the exact frequency) which puts it at around the 3db down point on the response curve, so you don't really need a lot below that point. On the other end anything with a strong response above 5-10khz for guitar will make it sound rather harsh and brittle.
When it comes to heavy overdrive that's part of what makes the OT in a guitar amp such a wonderful thing. It smooths out and removes a lot of the higher ordered harsh sounding harmonics and leaves you with the good stuff. The speaker does this even further, with most guitar speakers being rated for not much more than 5khz. If you've ever heard an amp recorded into a dummy load and direct into the computer without any speaker emulation you'll know what I'm talking about. Its sounds absolutely terrible.
