When you're really schlammin' the power, also at the moment of switching on hi voltage from standby, those can wreck resistors that can stand steady-state power levels without a problem. Some folks have had their mini resistors fail, although the math tells us they shouldn't. I've yet to see a good ol' fashioned full size one go bad in that application, even half watt parts. Which to use? Some like to have a resistor that will fuse under stress, that's OK. Personally, I use Dale 1% 3W wirewound for cathode current sensing. Take your choice & solder away. But I digress, the topic is noise and I've made enough.Littlewyan wrote:If you mean the Output Valve Bias Resistors I've used 1W for my output valves as the wattage dissipated across them is fairly negligible. However I didn't think about pulse current as I have to admit I don't know anything about it.
Resistor noise question.
- Leo_Gnardo
Re: Resistor noise question.
- Littlewyan
That's good info to know. Will bear that in mind. I have noticed that resistors have gotten physically smaller over the years which makes it very difficult when trying to determine what wattage resistors an old amp used!
Maybe I will purchase some 1W resistors and see if the noise level goes down.
pinkphiloyd
He also talks about the hierarchy of noisiness in resistor types as well. I only mention it because I've started messing around with metal films just about everywhere and hell, I can't hear any difference in terms of "sweetness", but my noise floor does definitely seem lower.Littlewyan wrote:Yeah but he was talking about carbon comp resistors. I just read his article. I may try ordering some 1W Carbon Film resistors just as an experiment to see if it lowers the hiss in my TW Express.
