I just made a jumper cable with a 100K resistor in series with two alligator clips. Simple and easy.
I would recommend anybody not familiar with a certain amp, to always double check the charge on a power filter capacitor with a volt meter before diving into the chassis.
Also there is a phenomenon called dielectric absorption that can generate charge to the cap in question, so it is advisable to leave the discharge jumper in place while servicing the amp.
Not sure I have ever observed that in real life but it is a good safety precaution to leave a discharging lead in place while servicing an amp.
Just don't forget to remove said jumper when you power up the amp.
