d-lite OT different primaries
Re: d-lite OT different primaries
That was recorded with the original prototype which used a 340-0-340 PT and stock Vibrolux OPT (4K primary, 4 Ohm secondary).  Running 6V6's, the reflected impedance is 8K to 8 Ohms.
Thanks normsterNormster wrote:That was recorded with the original prototype which used a 340-0-340 PT and stock Vibrolux OPT (4K primary, 4 Ohm secondary). Running 6V6's, the reflected impedance is 8K to 8 Ohms.
 Btw. I'm between using solid pine or birch plywood for the 1x12'' cab. Any suggestions for that one ? I would like to think that solid wood would be better choise.. I will be putting tolex to the cab...
mat
