I powered up the Galaxie 10 today with its brand new Output Transformer and... it sounds terrific! When I first got this amp (a friend snagged it from a yard sale for $25) it sounded horrible. I replaced the power tube with a JJ6V6S, which got rid of the squeal, but that only revealed other problems. I put in a Tungsol 12AX7 preamp tube, and replaced the stock Celestion Tube 10 speaker with a Weber Signature Series Ceramic 10.
The results were still unacceptable--- nasty, harsh highs and a "flubbiness" to the bottom end. Overdrive came out as just "fizz". It sounded so horrible I decided to sell the amp locally, but thinking about it, I knew I'd only get a hundred bucks or so. Then I remembered a discussion here at amp garage.com about how the output transformer was a piece of crap and should be replaced. I figured I'd already sunk time and money into the amp, so I should give that a try, and man, am I glad I did.
Hot mids, tight bottom end. A little treble-y, but nothing that rolling off the Treble knob doesn't fix. Crunch that sounds crunchy, not fizzy. I believe the amp's sort of a Fender type design, but now it sounds halfway between a Fender and a Marshall, if that makes any sense.
Martin, you mentioned that if I used the 7KΩ tap I could use a 6V6. I'm already doing that with the 5KΩ tap. Should I switch to the 7KΩ one? It'd be easy enough to undo the splice I did and splice in the other one.
Once again, everybody, thank you all so much for all your help. And as a way of expressing my gratitude, here is some Transformer Porn:
[img
[img:877:629]http://www.hallamgallery.com/silvertone/EXEF1.jpg[/img]
Look at that thing! That's in a three-channel guitar preamp built in 1990 in Germany, called the Triton. It's a wonderful sounding piece of gear which I use as an amp, going right to a speaker cabinet rather than to an external power amp. It's old and has some hum to it, so now that I know how to safely discharge the voltage, I've decided it's time to replace the caps. When I took off the cover and saw that transformer, I thought at first it was the Large Hadron Collider.
[img
