mhuss wrote:KGW wrote:
On my Hotplate, I can hear the sound degradation at any attenuation level.
A lot of people have said this (about many attenuators). There's so many physical and psycho-acoustic things going on, I wonder if it's not just the attenuation itself. In other words,
I'll bet even a theoretically "perfect" attenuator would appear to color the sound, just because "quieter sounds different,"  and a change in volume affects the physics (speaker/air/guitar) differently.
--mark h
mark,
i won't even address the physics of sustain/acoustic feedback.
i'm not remotely qualified to do so in a comprehensive manner.
suffice it to say, this can be a part of the equation that should not be dismissed.
is my opinion that a purely resistive attenuator's affect on the loading of the amp, and the damping of the speaker, is the largest
single factor affecting tone.
IMHO, the psycho-acoustic phenomenon, and physics run a
close second and third.
a friend and i, put together a small multi-track recording studio in the early '80s.
when i made recordings of his band, he was able to
eventually adjust to hearing his guitar through headphones,
with his amp mic'ed in an isolation booth.
many others were not so quick to adapt, and their performances suffered.
we often did "band" recordings, with all instruments and vocal recorded simultanteously, but on separate tracks.
since the drums were only allotted 2 tracks "for stereo", i needed to focus on getting their mix perfect.
i only needed to hear (in the control room) the other instruments well enough to get a clean recording.
a guitar player that was in the control room with me, thought the quiet guitar sounded like dung.
however, i played back the guitar track alone, without additional effects, but at a louder level.
the guitarist was amazed at my skill in extracting such a wonderful tone from such a lackluster recording.
needless to say, when i judiciously panned the guitar and suBtle temporal effects for the final mix, i was now seen as some sort of Genious.
while i'll admit i could make a guitar sound as big a house, without being
rediculously loud, part of it had to do with listening level.
during the playback for the final mix, the volume level in the control room was always more modest.  you want to hear things the way a person would in an "average" listening environment.
the bottom line is:
YES, volume does affect the perception of "tone".
mhuss wrote: ...
KGW wrote:
Another issue is that lower frequencies draw more power. On top of that, the impedence and power all change with frequency.
Only on a real speaker, not a resistor. So, this may affect the sound, but it will only marginally affect the power dissipation in the resistive attenuators we're talking about, as we're typically sucking up 2/3 or more of the power with resistors, even at mild attenuation settings. ...
i view this a bit differently, mainly having to do with how much energy is required to achieve "equal loudness" at different frequencies.
but that's a conversation for another time.
my fingers are getting tired.
cheers,
unk
