I changed the NFB scheme, removing the separate lines from each preamp to the 22k resistor, and connected the 22k resistor from pins 3 & 8 on the PI to the 8 ohm tap on the OT. Didn't stop the thumping, and didn't seem to make much difference on the sound.
I measured the voltages at each of the 5 nodes on my power supply. Note that the first node (called B+) isn't used. Here's what I see:
B+, 465 VDC, 1 VAC
B+1, 441 VDC, 0.8 VAC
B+2, 438 VDC, 0.6 VAC
B+3, 405 VDC, 0.5 VAC
B+4, 400 VDC, 0.5 VAC
I'm getting a bit of AC on the B+ measurements, but it's not much. Don't know if it will make a difference.
Also, the voltage between pins 3 and 8 on the power tubes is 400 VDC, and the voltage between pin 8 and ground is 39 V.
Also, after messing with this thing this afternoon, I need to clarify the thumping sound. About 15 seconds after I turn on the standby switch (turn on the B+), the thumping starts. It lasts for about 15 seconds.
Tillydog wrote:To add to the above, the volume and tone controls are inside the NFB loop as drawn - which will cause much weirdness (maybe not your thumping, though). Another reason to move it to the PI.gar13 wrote:I see a couple of problems with the way the NFB is employed here. ...
Also, I don't see a grid leak resistor on the top half of V2 - this could be related to your thumping. The cross-coupling of all the V1B cathodes could cause funny things to happen, especially if all the V1s are fed from the same B+ node, but overall, I tend to concur with the thought that the power supply filtering is insufficient.
Andy
 OK, so your feedback tap now works, but you need to to flip the OT primaries (OR secondaries, OR output tube grid connections) to get the phase right.
