Small Special
alvarezh
Re: Small Special
Post by alvarezh »
Thanks again!
Cheers!
Horacio
Play in tune and B#!
jon
Re: Small Special
Post by jon »
alvarezh wrote:Thanks for the info Jelle, any chance you could name (model of 6L6 / brand) the power tubes? :)
Thanks again.
All the best.
Mesa STR440 Pulls
alvarezh
Re: Small Special
Post by alvarezh »
Thank you Jon, very kind of you.
Enjoy it!
All the best.
Horacio
cornel moldovan
Reversed capacitors
Post by cornel moldovan »
Sorry, but you made a mistake...i noticed it at the first sight... your coupling caps must be turned 180 degrees ,cos in this manner you have hum noise ... the marked side must be soldered to the plate...AM I RIGHT OR WRONG? :idea: [/b]
wjdunham
Re: Small Special
Post by wjdunham »
On the subject of the small special, I got to play a Morgan SW50 which is a sort-of clone of a Small Special that came in to Morgan's shop last year. It's not an exact clone, uses Jupiter yellow caps throughout for example, but otherwise looks pretty close. I was quite surprised how the amp sounded and felt, plenty of really warm clean breakup at reasonable volume levels. There is almost no high end filtering going on in these things (no snubbers, no grid stopper on V1B, and a 100pf bright cap that is always engaged, switch can add another 250pf), but the amp was not harsh in the least. Stock JJ preamp and Tung-Sol re-issue 5881's. Comments on where the mojo is coming from in these things? I have not built one, but hearing that amp may change my mind.
Jelle, do you get this amp up and running yet?
Bill
jelle
Re: Small Special
Post by jelle »
I guess that depends on the goal... The idea here was to make a small special clone with a twist, the jfet. The original amps have it the way it was done here.
No error, design choice from our end. No hum, either...
qtone
Re: Small Special
Post by qtone »
Really pristine inside looks fantastic as usual.
Jelle could you drop me a pm here.
Thanks qtone.
jujudubluz
Re: Small Special
Post by jujudubluz »
jelle,
did you used the "60's dumble" schematic which has been online for years?
"less is more" mies van der rohe
jujudubluz
Re: Small Special
here's what i've been working on:
-schematic
-i started a layout too...
let me know what you guys think...
juju
jujudubluz
Re: Small Special
here's my own layout
dreric
Re: Small Special
Post by dreric »
jujudubluz wrote:here's my own layout
That's a cool layout, what software did you use?
Eric
jujudubluz
Re: Small Special
@ dreric:
Autocad, it's a wonderful tool in 2D and 3D, i use it everyday.
ChrisM
Re: Small Special
Post by ChrisM »
jujudubluz wrote:here's what i've been working on:
-schematic
juju
Quick look,
Your missing a coupling cap after the 2nd gain stage.
jon
Re: Small Special
Post by jon »
jujudubluz wrote:@ dreric:
FYI there is a great free CAD program called draftsight
jon
Re: Small Special
Post by jon »
I need a little bit of speaker advice. I just bought a Reason Elite 2X12 from Anthony. I have one EV 12 Force speaker. What would you pair it with? I do have a WGS ReaperHP 50W speaker, but that would limit the cabinet to 100W, marginal at best with this amp.
http://www.stagecraftgear.com/servlet/t ... x12/Detail
http://wgs4.com/content/ReaperHP
