Thanks!Luthierwnc wrote:You should be able to bridge them. The phase is the same at the jacks. If you don't want to, here's the switch for one or the other. I put grid leak resistors on both sides because a shared resistor on the jack side of the switch can pop. You could also just put the grid leak resistor between two throws on one side of the switch so when one side is grounded, the other has one meg referenced to ground. sh
I thought the signals would come out of the preamp out of phase. One goes through two triodes (two inversions), one through a pentode (one inversion).
 I was just pretending to be humble
 I was just pretending to be humble   No really, I mostly feel like everybody else are experts compared to me.
