On my 4 current amps I have 4 different relay supplies.Luthierwnc wrote:Bob, I'm not sure but somewhere (here or maybe the GearPage) I read that some folks didn't like having the relays on the mains transformer. I use a separate transformer.
1) Weber switch board. easy to install but the DIY in me wanted to do it myself.
2) Unregulated 6V supply off the heater windings.
3) Regulated 5V supply off the unused 5VAC tap
4) 12V regulated using a seperate 12VAC xformer. This one started by using the bias supply line but I had terrible noise issues, hum and diode noise both.
The resistor on the red LED is 48 ohms and the one on the green is 120 ohms. It is just enough resistance to light the LED but it has an independent signal to ground so the relay trips. In the case of the amp I'm finishing, the 12v line is also the indicator light supply for the D-lator switch so it needs to be available without a relay.
Great idea. I was thinking that there's no reason that we can't install the HRM controls on the panel. Why not have some tone adjustment with OD/PAB.BTW, until tonight, I used a DPDT stomp switch for the OD. It is in a two switch Hammond box. The boost is just SPST. The OD switch has the feed for the OD and another for the boost in parallel with the stand-alone boost switch. I built the HRM first. Since both tone stacks muddy the sound, I rigged it so hitting the OD would turn them both on but the boost could be used independently. I'm using the same stomp box for the Hybrid now so I went back to the usual method. I've got wide feet so I can get them both with one step.
