Transformer recommendation..
Ian444
Re: Transformer recommendation..
Post by Ian444 »
Ooops, forgot about the center tap...
250V rectified would give 350V with no load, but under load, more like 320-325V. Then theres losses through the tube rectifier.
Tdale
Post by Tdale »
that's withouth a center tap?
Ian444
Post by Ian444 »
250-0-250 or 0-250. It works out the same.
Tdale
Post by Tdale »
Hmm..
I thought that 250 - 0 - 250 gave a theoretically output of 500V (two fases)....
Tommy
Hellhammer
Post by Hellhammer »
Ian444 wrote:Ooops, forgot about the center tap...
Yes I was only using it as an example, comparing centertapped and no centertap. 5V heater tube rectifier? Well that narrows it down further. So you need a 5V winding as well.
/Stewart
Hellhammer
Ian444 wrote:250-0-250 or 0-250. It works out the same.
Well the current ratings differ.
If your 0-250 PT is rated for 100mA AC, you'd get ca 60mA DC out of it and that would be a lot for the PT, you wan't some reserve.
From a 100mA, 250-0-250 PT full wave rectified, you could get ca 100mA DC, but again you do want some reserve.
Tdale wrote:Hmm..
Tommy
It does but can be used for a 250V output as well. Read the Hammond design guide. It's all there.
/Stewart
Ian444
Post by Ian444 »
https://tubeamparchive.com/viewtopic.ph ... 916#100916
Tommy, there's some good reading here , look for the heading "The Power Supply", and have a look at these 2 topics - "Two-Phase, Full-Wave Rectifiers" and "Bridge Rectifiers". That will explain the voltages.
Hell, yes, lets just make it up as we go then, what do you reckon? ;)
Tdale
Post by Tdale »
But If I need a 250 - 0 - 250 transformer, a 0 - 250 won't do it.... The first has 500V between the leads, the other has 250V.....
Tommy
Hellhammer
Oh yeah and if you're using a valve recto you need the centertap or you could do a hybrid like this: [img:350:160]http://www.freewebs.com/valvewizard/Bridge3.jpg[/img]
/Stewart
Hellhammer
Tdale wrote:But If I need a 250 - 0 - 250 transformer, a 0 - 250 won't do it.... The first has 500V between the leads, the other has 250V.....
Tommy
Tommy! You're not reading the links we're posting! ;)
You could use either. A 0-250 would need a higher current rating and a bridge rectifier though.
/Stewart
Ian444
Post by Ian444 »
+1
