New 50 watt build
Re: New 50 watt build
I have read that the Ceria chassis are a thinner gauge aluminum.
Plus they are a non standard width.
67plexi
Post by 67plexi »
Call her done, Just found a NOS pair of Tesla EL34 OO getter, Sweet.
GE long plates 7025’s V-1/V-2, Siemans E83CC V-3 date code 1960.
465 volts on the plates.
481 B+
1202-55 Power transformer, primary taps, 100v, 120v, 220v, 230, 240v.
784-139 Output transformer, 3.5k.
Fender Twin choke.
Bias set cold -32mA.
Build the combo cab time.
67plexi
Post by 67plexi »
New knobs :D
CHIP
Post by CHIP »
Steve,
those are cool, where did you find them? I need some knobs for my D'lite since i took those off for my new amp.
67plexi
Post by 67plexi »
The Combo cabinet in the works, Tolex and grill cloth is on the way.
I built the cabinet one inch taller to accommodate a 15” speaker.
Will build a 12” and 15” speaker baffle board to see what works best.
David Root
Post by David Root »
Nice knobs, and nice tube line-up! I also like the VOX style combo cabinet, you can slide the amp in and out.
Let us know how it sounds with those vintage tubes!
dcribbs1412
Post by dcribbs1412 »
looks great cool knobs...gotta ask, can you divulge the source
15" is a cool idea
covering it with voxish grill and suede?
67plexi
Post by 67plexi »
Time to paint it black. The 15" speaker fit. :D
67plexi
Post by 67plexi »
Tolex time.
Post by Mark »
Where are those round knobs (front panel) available from and how close are they to the real thing?
Yours Sincerely
Mark Abbott
talbany
Post by talbany »
Steve
Looks good so far!!..What kind of 15 do you have in mind..Here are my faves in current production ceramic
EV15L
Delta Pro 15 and believe it or not the Eminence Legend ain't half bad for the money and a bit lighter too..
I recommend a beam blocker if you go w/15 thought I'd mention.. Have Fun!!
FWIW..I tried mine w/oval back and closed back acoustic suspension..I much prefer the AS
Post by Mark »
I haven't heard of the acoustic suspension part of this term before, is this more than the typical closed backed cab?
Let's not forget about the knobs?
Yours Sincerely
Mark Abbott
talbany
Post by talbany »
Mark..What do you mean by more?..
I think they used to call closed back Hi Fi speakers acoustic suspension since the speaker is cushioned by the enclosed air.
67plexi
Post by 67plexi »
Mark the knobs are Alcoknob KES-700AB made in Japan. Pre Fukushima.
The 15” speaker is an Eminence sounds good out of the cab. Will see how it sounds in the cab today.
I’m working on a 12” baffle if the 15” speaker doesn’t work out.
Still waiting on my tolex and grill cloth, brown alligator and fender wheat grill cloth.
Hope to finish this week; I have a show to play on the largest stage in town this weekend.
If not I will use #183 100 watt and #124 100 watt.
Thanks for all the kind comments
Steve.
