this way you can obtain an AUDIO pot with good caracteristic, better than some audio pot you can find in the market
this way is possible also to obtain a cheap AUDIO REVERSE pot, it is sufficient you connect the resistor to the wiper and to the other side of the potWhen we buy "audio taper" pots, we usually get something like Curve 3. For less expensive pots, manufacturers use a two or three-segment approximation to Curve 2. It's not perfect, but it usually works OK. Curve 4 is the typical resistance versus rotation curve for reverse log pots. In real life - that is, if you ever found one of these in real life - it is usually a two or three segment approximation, too.
one other way is to use two cascaded pot in series, one 1MA and the other 100KL to have a fine regulation (we used that trick many years ago in radio receivers as to obtain a fine tuning), but I don't like to have 2 pots for a MV instead of one, if not strictly necessary
Kagliostro
