This is why you should power up an amp that you are not familiar with or have made changes to the power supply with a light bulb current limiter.
It can keep the smoke in if there is a short or other wiring fault.
Pretty cheap insurance.
If you start with a 25w light bulb it limits the current to less than 250ma to the amp.
What happens is, you connect the limiter, turn on the power to the amp.
If there is a filter cap before the standby switch then this will cause the light bulb to briefly flash, then go down to a low glow.
Flip the standby switch to play and the light bulb will flash again then go down to a low glow.
If the light stays brightly lit after either switch is closed, then you have a short or other wiring fault and you should immediately turn the power off.
It's a good idea to put a power switch on the light bulb current limiter to be able to kill power quickly.
If the 25w bulb test passes muster then power down and screw in a 60w light bulb and repeat the test.
If it passes that, then install the tubes and try it again.
The bulb will glow a little brighter because of the tube load drawing more current.
Good luck.
REMEMBER: Anytime there are power tubes in an amp you must have a speaker load connected or you can fry the output transformer and tubes.
