Yes, V1a, V1b, V2a, and V2b. The PI is quite a bit higher, output tubes about 430V. It may take some fiddling with the dropping string.
Also, Dumble used an input with an FET driver, most likely for cleaner type sounds. The load that puts on the power supply is about 15K. Dogears likes to use a load resistor at the end of the PS rail, 15K 2watt to simulate this load. This will also adjust the voltages.
also, Dumble used an input with an FET driver, most likely for cleaner type sounds. The load that puts on the power supply is about 15K. Dogears likes to use a load resistor at the end of the PS rail, 15K 2watt to simulate this load. This will also adjust the voltages.
Someone mentioned earlier that alot of it comes from the player, which is true. Bob is a great player and sounds good on any amp I've heard him play on. I've played through his "crumble" and ODS with his guitar and trust me, it fits his way of playing much more than mine, though the ODS is more forgiving, tonewise, especially if ya got clam hands. If I were going the Dumble route, that's personally the layout I'd start with but it's pretty complex (not that that's ever stopped me from getting in over my head, before). The real reason is I just don't know if I could afford all those pots!
