 Tdale wrote:Great photos!
Someone asked about the plate resistors looking like 100K.. I'd love to know the values too.. I had a schematic with 100K resistors, but was told that they should be changed to 220/150 180/150...
Also, the OD entrance trimmer is interesting, even if it's not 500K as written, but more like 350K... It's still much higher than the 100K we usually use... Any reason for this?
Tommy
Normster wrote:The OD input is quite a bit different. Notice that the trimmer is wired as a simple rheostat, not a potentiometer. I didn't do the math, but I suspect that the total signal that makes it to the grid is actually hotter with this series circuit than with the series/shunt we're used to seeing.
A couple of clarifications:dogears wrote:Thanks Gil!! A few surprises under thar goo fer sure...
However, my suspicion over the use of large V1 bypass caps is confirmed. I guess the old boy used the larger pre OD net values and drive pot to smooth the 100k plates?
Your schematic shows 120k feeding the trimmer. Your description mentions 220k. I think the picture shows 120k but I can't tell for sure.
Good question on the carbon feedback resistor. Did anyone measure it? I suspect it may be a bit high?
Anyway, thanks again! Great work!
