I found it after talking with Norm and we were discussing how to ground out the OD channel. I just checked continuity on the Drive pot and OD level pots from the in (hot) to ground.
 The amp still has some tweaking to do. I have the 3.3k resister on OD1 and 1uf electrolytics on CL2 and OD2. Mouser sent the 5uf on Friday!
 ) ect. - thanks to you for your layouts and discussions as well I definatley picked up some tricks from you!
 When are you starting your ODS?
