If you buy the weber 5F6A kit sans transformers and tubes, you can put whatever 5F6A-spec PT and OT and choke you want on the back of it.
https://taweber.powweb.com/store/kits_50a.htm#5F6A
If it is 5F6A spec it should fit, and you can ask CJ Sutton at Weber about what ones will fit the chassis if you are in doubt. ( And even if anything you buy doesn't fit, its usually nothing that a hand-drill and bit of elbow-grease with a metal file won't fix).
There are other brands of trannies on the Weber site for 5F6A amps e.g.:
OTs
Heyboer HY022855 ($68 )
Mercury FO50BM-2 (OFBF-50) ($136)
(But even the Weber one will work fine, and it is included in the overall kit price of $680)
PTs
Heyboer HY022798 ($78 )
Mercury over the top range depending on voltages etc that you might want. I'd shoot for something that gives a B+ of ~430VDC when plugged into your particular mains wall voltage.
(But even the weber brand one will be fine if its US voltages, and its included in the kit price)
Chokes
Mercury C	FC-TBAND ($38 )
Even the weber brand one will work fine (and its included in the kit price)
The Weber speakers are awesome, and you can put whatever combination you want in (if you don't go for the stock sig10s included in the kit price).
The other parts, pots, resistors caps etc and rats and mice cost and you can easily ditch whatever you want.
Regarding your question about cap markings earlier, see the attached  blurb on E-series cap markings. For the purpose of guitar amps, caps are typically marked for a maximum DC voltage rating (e.g. 400 or 600 etc) and their capacitance value either in microfarad (uF), nanofarad (nF), or picofarad (pF) values. (1farad = 1,000,000 microfarads, or 1,000,000,000 nanofarads, or 1,000,000,000,000 picofarads). Hence .1uF = 100nF and .022uF = 22nF and .001uF = 1nF = 1,000pF etc.
Resistors are usually colour-coded, but the colour-coding varies in different countries, so you should have a multimeter handy to check them before you solder them in anyway. (And you'll need to tool-up with a range of basic tools including one or more multimeters, if you're going to build your own amps). Theres a lot of mojo talk around about which resistors are better for what. If you don't like hiss, then use metal film (MF) types for plate and grid-load and cathode load resistors, otherwise the higher the power rating of the resistor, the less likely it will be to hiss anyhow.  You need to be aware that carbon comps (CCs) are the most prone to heat damage by over-soldering (causing drifting in resistance values) if you're planning on using them.
Tubes you can trying to your heart's content once you get the amp built and functioning normally.
