 Tony, Martin
 It's a Mr D amp...192 (I thinkthe photo is of MrD's amp right, or is it from the amp you built, Tony?
 )Here is the other side..Pin's wired for 6L6's so diode and cap off the primary right to gnd (pin 8 )
 )Here is the other side..Pin's wired for 6L6's so diode and cap off the primary right to gnd (pin 8 ) Tony
 The closest I got to this was with this https://passive-components.eu/transform ... lications/. I don't understand the capacitor to be actually limiting the transformer bandwidth, quite the opposite: if anything it seems to be reducing the THD and increasing the reflected load. Thinking of the tranformer output gain as a horizontal line, distortion starts with the onset of return loss* at the knee at higher frequencies. The capacitor offsets the point where the return loss knee starts to decay to a point higher in frequency, flattening and broadening the output gain further into the inaudible frequency range.
 ]check equivalent schematic of real transformer, and ask your self what is happening when one node you pull to the ground with capacitor? you are running all that reactances with internal tube resistance which is in kiloohms.. pentode is in several tens of kilohms..Stephen1966 wrote: ↑Sat Sep 18, 2021 11:59 am The closest I got to this was with this https://passive-components.eu/transform ... lications/. I don't understand the capacitor to be actually limiting the transformer bandwidth, quite the opposite:
You will have to elaborate for me to grasp the finer points here, but are you suggesting the cap provides a low impedance path to ground for higher frequencies; a low pass filter? Bearing in mind the effect of Return Loss, this seems counterintuitive. If I understand you well, you are saying the low pass filter effect is the dominant and more audible. Further, that the concept of the LPF might be used to determine the value of the cap and the roll-off of the high frequencies.bepone wrote: ↑Sat Sep 18, 2021 12:20 pmcheck equivalent schematic of real transformer, and ask your self what is happening when one node you pull to the ground with capacitor? you are running all that reactances with internal tube resistance which is in kiloohms.. pentode is in several tens of kilohms..Stephen1966 wrote: ↑Sat Sep 18, 2021 11:59 am The closest I got to this was with this https://passive-components.eu/transform ... lications/. I don't understand the capacitor to be actually limiting the transformer bandwidth, quite the opposite:
Very interesting, I would like to see those graphs.bepone wrote: ↑Sat Sep 18, 2021 12:50 pm offcourse, without 470pF from anodes to the ground bandwith of preamp and power section (preamp is dominant) is maybe 20-30kHz roughly speaking without calculation, with 470F from anodes is maybe 15-20kHz.. i have somewhere some graphs..
see the bartel amp or tone king, they are using this often
Stephen1966 wrote: ↑Wed Sep 15, 2021 5:24 pmThank you Andy, I'm happy to stand corrected... Great tip about the volume with and without the NFB, but "bark" and "tweet"... when? We all love a cliffhanger but the suspense is killing meFUCHSAUDIO wrote: ↑Wed Sep 15, 2021 4:16 pmStephen1966 wrote: ↑Sun Sep 05, 2021 12:00 pm
Good to know, thanks. I'm just thinking what else I would need to do if I swap the PI plates' wires, maybe swap the plate resistors as well? Hmm. I'm hoping it doesn't come to that. The output section just after the PI is all but equivalent either side of the PI but the grid and cathodes are pretty well baked in to the circuit with half the stage fed by its grid and the other half by its cathode . Is this 50/50 because of the OT windings or the PT? It was Andy Fuchs who mentioned something about reversing the HV leads from the PT to remove oscillation. Is this not a better solution to the problem than re-engineering the LTP?
If the neighbours complain, I just send the wife out. She's in PR so it's just like homework for her
To be clear: My comment about reversing phase was for output transformer plate leads. If you have nfb, and the amp oscillates, you may actually have positive feedback, and the plate leads need to be swapped. Easy test is to lift the NFB wire from the speaker jack and if the amp gets louder, you have things correct and you have negative FB. You may need to look elsewhere if you have instability or problems with your output stage. If the leads are reversed, the amp would get quieter when you lifted the NFB wires and that shows you have positive feedback, which is wrong. I've seen amps work and sound okay, but "bark" or "tweet" when
IMO.. You would be correct in assuming thatIt isn't so much about the power it has to handle during normal operations, rather what happens to it when there is a surge.
 (Tony, I've put your link in tags - couldn't see it in your post...)talbany wrote: ↑Sat Sep 18, 2021 5:16 pm .IMO.. You would be correct in assuming thatIt isn't so much about the power it has to handle during normal operations, rather what happens to it when there is a surge.
AFAIK..Peavey used the STR-2873 for their fly back diodes
https://www.tubeampdoctor.com/en/overvo ... eavey-amps
(BTW? They don't need to be FRED's, since they shouldn't normally be conducting)
As far as the cap goes? I always thought it was there to suppress runaway oscillations? but am curious to know otherwise
Here is a shot of the other sockets
