Enjoy!!
Yes it does, that's a transitional 4th gen classic TS right? Regardless, thats the TS in my "004" build, only with a 1.8K tail.talbany wrote:The amp was voiced for a Stratocaster and is reported to sound wonderful!!.. Notice the tone stack..![]()
Check the 150k slope..ToneMerc wrote:Yes it does, that's a transitional 4th gen classic TS right? Regardless, thats the TS in my "004" build, only with a 1.8K tail.talbany wrote:The amp was voiced for a Stratocaster and is reported to sound wonderful!!.. Notice the tone stack..![]()
TM
I have a 150K slope in mine as well. On my list is to remove that bastardized skyliner TS in my first quad 6V6 build and install this one as well.talbany wrote:Check the 150k slope..ToneMerc wrote:Yes it does, that's a transitional 4th gen classic TS right? Regardless, thats the TS in my "004" build, only with a 1.8K tail.talbany wrote:The amp was voiced for a Stratocaster and is reported to sound wonderful!!.. Notice the tone stack..![]()
TM![]()
T
MikeToneMerc wrote:talbany wrote:Check the 150k slope..ToneMerc wrote: Yes it does, that's a transitional 4th gen classic TS right? Regardless, thats the TS in my "004" build, only with a 1.8K tail.
TM![]()
T
TM
EJ?Has been made for a 1956 maple neck strat
ToneMerc wrote:that's a transitional 4th gen classic TS right?
If this schematic of #0094 is correct https://tubeamparchive.com/viewtopic.php?p=56783#56783 , then at least #0094 has a 150K slope resistor, too.talbany wrote:That's the first Classic stack I've seen with a 150k slope.
AFAIK the musician and first owner who ordered both amps - each one with a matching 2x12" cabinet and a mono Dumbleator - isn't Bruce Sandler.talbany wrote:Has been made for a 1956 maple neck strat. It is the sister amp of the one Bruce Sandler offers at gbase with the matching 2 x 12". He ordered both with the export transformer (touring player)
MaxAn example for a "transition generation classic" ODS (high plate version) is #0094: https://tubeamparchive.com/viewtopic.php?p=56697#56697
Tony, I don't know which pictures ic-racer used to identify the slope resistor of #0094 to be 150k. But AFAIR Gregor Hilden posted some more detailed pictures of #0094 as a part of the item description for the eBay auction. So perhaps ic-racer had a more detailed picture at hand when he drew this schematic of #0094. But perhaps ic-racer may chime in and explain why he thought the slope in #0094 to be 150k.talbany wrote: Looking at the pics Gregor posted of 094 I cant determine the value of the slope so IMO if this schematic was drawn up using this pic I would have suspect.
So you think that sticking needles thru the goop - as you wrote - is a trustworthy method for figuring out the circuit of a gooped ODS?since we don't yet have a ODS layout w/ internal HF taper I'll see if I can revise the 102 layout to 123 specs
